2005 ZX3 no overdrive when button is engaged - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > South East Fanatics > Fanatics: Florida
Fanatics: Florida Regional discussion Forum for planning events and sharing information with all Members in the Florida areas.
Old 02-16-2013, 12:12 AM   #1
Dirtscratcher561
Fan#: 109947
What I Drive: 2005 Ford Focus Green ZX3
FF Reputation: 1 Dirtscratcher561 Good Standing Member
Angry 2005 ZX3 no overdrive when button is engaged
I have a 2003 ZX3 with 80,000 miles on it and when the overdrive button is engaged, it will slip out of gear and rev up high. When I have the OD disengaged. the shifting from first to second happens at about 4000 rpm and sometimes when I let off the gas. When I get it going into second it wont change into another gear. If I press the OD button, the gear slips out like it is in neutral and wont engage. I have changed the fluid and filter, SSA and SSC, the TPS, and still it hasn't gotten better. I have had a code scanner hooked up to it and no codes show. The OD light sometimes will blink orange but then goes green after the car has been off. I had read that maybe hooking up the code scanner and clearing the code and resetting the pcm might help. Any ideas. Thanks.
Dirtscratcher561 is offline
