How do I disconnect the battery? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2013, 11:12 PM   #1
FamousMassacre
Fan#: 104066
What I Drive: 2013 Performance Blue Hatch
Points 1,776, Level 24
Points: 1,776, Level: 24 Points: 1,776, Level: 24 Points: 1,776, Level: 24
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 FamousMassacre Good Standing Member
I can't for the life of my figure out how to disconnect my battery...
Any info?
FamousMassacre is offline
Old 02-15-2013, 11:22 PM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Any info?
Start with removing the ground cable on the left front strut tower, then remove the positive terminal which is the forward terminal on the battery. It would require removing part of the cowl shielding to undo the negative terminal, but the ground line will also act as a surrogate negative.
suss6052 is online now
Old 02-15-2013, 11:25 PM   #3
FamousMassacre
Fan#: 104066
So I can disconnect the negative post of the battery from this?
I was thinking I had to go to the very back and get it from there.
To take off the negative, I just unbolt it from the back, right?
Old 02-15-2013, 11:26 PM   #4
FamousMassacre
Fan#: 104066
How do I take off the positive one?
Old 02-15-2013, 11:32 PM   #5
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 22%
It should just unbolt, however I'm not 100% sure on which size bolt/ nut it is, as I haven't had to remove the battery connections yet. If all you want to do is reset the computer removing the ground cable should be sufficient for this afaik.
Old 02-15-2013, 11:34 PM   #6
FamousMassacre
Fan#: 104066
No, I'm working with wires connected directly to the battery for a sound system.
How do you unhook the positive?
Old 02-15-2013, 11:39 PM   #7
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 22%
Didn't I just say it should unbolt or unscrew? If you're looking at the car it should tell you exactly how that attachment works. I don't have access to a service manual, but it should not require one to disconnect the positive terminal which is right in front of you. the only tricky one is the negative which is under the cowl.
Old 02-15-2013, 11:49 PM   #8
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
The nut gets loosened that faces up on the positive terminal. I see youve removed it in the picture. This style of clamp gets stuck on. The nut doesn't have to be removed just loosened. It's a 10mm bolt I think. This nut I'm talking about can not be used to make connections you would be better to just attach here
Zoomed out a bit
Or get new terminal clamp
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 02-15-2013, 11:50 PM   #9
FamousMassacre
Fan#: 104066
...really?
You just said I could disconnect from the ground on the right side of the car(facing the front).
I've never disconnected a battery like this and I have no idea what to do.
Old 02-15-2013, 11:55 PM   #10
FamousMassacre
Fan#: 104066
Zoomed out a bit
So you're saying to connect my wire terminals here?:
I've had it where it is in the picture and it's been fine.
