GPS Errors - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2013, 08:46 PM   #11
focus wht
Fan#: 49023
What I Drive: 2013 Focus TI White Platinum
FF Reputation: 1 focus wht Good Standing Member
I had the exact same issue. Simple fix, open hood and disconnect cable from the battery for about 5 minutes. Reconnect and the system will reset and the vehicle location has been bang on since.
focus wht is offline
Old 02-19-2013, 08:51 PM   #12
bvrplzr
bvrplzr's Avatar
Fan#: 108628
What I Drive: 2013 performance blue focus titaniu
FF Reputation: 1 bvrplzr Good Standing Member
mine started doing this when i first updated it does it every once in a while but it is doing it less and less as time goes by.
2013 performance blue focus titanium hatch
2008 yzf-r6
2001 grand cherokee
bvrplzr is offline
Old 02-19-2013, 08:52 PM   #13
lddavis
Fan#: 104180
What I Drive: 1997 Red Outback
FF Reputation: 2 lddavis Good Standing Member
Same idea -- remove the power to the nav unit. Disconnecting the battery will kill it everywhere in the car, so you might reset more than you wanted. But the battery is easy to find and you don't have to look up fuse positions in the manual.
lddavis is offline
Old 02-20-2013, 09:50 AM   #14
TiPilot
TiPilot's Avatar
Fan#: 93667
What I Drive: 2012 Ingot Silver Ti Hatch
FF Reputation: 1 TiPilot Good Standing Member
Originally Posted by lddavis View Post
I've seen reports on other forums of a problem with the GPS being offset that was fixed by pulling the fuses to the nav and APIM (and putting the fuses back in, of course :))
Good to know - I'll have to give it a whirl.
Haven't pulled the fuses since delayedreboot.cab came along... it'll be like a trip back in time!
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg
Build Date: 12/2/2011 | New APIM: 4/4/2012
MFT: Factory v2.11, 3/14/12 Web -> v3.0.2, 9/24/12 Web -> v3.2.2, 1/24/13 Web -> v3.5.1, 8/13/13 Web -> v3.6
TiPilot is offline
Old 03-16-2013, 08:58 PM   #15
4havnfun
Fan#: 107430
What I Drive: 2013 Blue Candy Titanium
FF Reputation: 2 4havnfun Good Standing Member
OP here. Pleased to report that pulling fuses 67 & 79 for a while solved the problem. Thanks for the solution.
I decided that I didn't want to deal with pulling the battery because of the DCT learning cycle and because they made the negative terminal way too inaccessible. I mean really, how hard would it have been to put the battery in so that the closest and easiest terminal to access would be the negative. Safety please.
4havnfun is offline
Old 03-16-2013, 09:00 PM   #16
suss6052
suss6052's Avatar
Fan#: 95752
Points 9,903, Level 66
Points: 9,903, Level: 66 Points: 9,903, Level: 66 Points: 9,903, Level: 66
Level Up 64% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
There is a main ground cable on the left front strut tower, this is the main body ground, disconnecting this acts the same as disconnecting the negative terminal and is used for jump starting cars also.
You don't have to reach under the cowl to directly disconnect the negative terminal on the battery.
suss6052 is offline
Old 03-16-2013, 09:09 PM   #17
4havnfun
Fan#: 107430
Thanks for the suggestion but there is a 2nd thinner ground wire connected directly to the battery terminal that goes somewhere. I could have disconnected the ground strap and then pulled the positive connection to be 100% certain but I preferred to not have the DCT lose all of its adaptive calibration so I went the contortionist route to pull the 2 fuses.
I still stand by my view that they could have made it much simpler and safer by just flipping the battery around.
4havnfun is offline
Old 03-16-2013, 09:22 PM   #18
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
Sub'd, in case I ever need to do this with mine, I'll refer to which fuses to pull! Thanks!
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 04-08-2013, 09:33 PM   #19
4havnfun
Fan#: 107430
OP here, 3 weeks after pulling the fuses and the problem has come back.
4havnfun is offline
Old 04-09-2013, 08:15 AM   #20
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,491, Level 21
Points: 1,491, Level: 21 Points: 1,491, Level: 21 Points: 1,491, Level: 21
Level Up 91% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Fuse pulls, battery disconnects don't tend to fix these kind of problems, just make them better for a while. The problems do tend to eventually creep back in. Reboots do the same thing (fix issues for a bit but not permanently) and are not as inconvenient as crawling around pulling fuses or disconnecting battery cables. I don't know if you use this or not already but if you do not there is a little reboot app that can be found here:
http://outofmytouch.com/reboot.html
Basically you put it on a USB drive, pop it in before you shut the car down, let it install, remove the drive, and shut the car off. This causes the MFT system to reboot while the car is off. Really cleans the system up for a bit. If it starts acting up, you can do it again when necessary. I keep a copy on a drive permanently in my car for when I need it.
Note that a reboot is different than a master reset. Master resets wipe out all your stored info (nav destinations, radio presets, phone pairing, etc.) and don't accomplish much. Reboots (which is what is occurring if you have ever seen the "performing system maintenance" screen) seem to help the system a lot more than resets in my experience.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
