inside fan making screeching noise !!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2013, 05:38 PM   #1
Cheif117
Fan#: 108702
What I Drive: Ford focus 2004 mk1 1.6 dark green
FF Reputation: 1 Cheif117 Good Standing Member
Hey guys recently the inside interior fan has been making alot of noise when the fan power is on 4. it is so loud u can hear it from outside.
now i know how to access the fan and take it out but what i dont know is what to lubricate to stop the noise
Cheif117 is offline
Old 02-16-2013, 01:04 AM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
Take it out, there is probably some debris in there rubbing.
Mine was making a scratchy sound, it had leaves wrapped around the commutator. These cars do not have a cabin air filter, so stuff falling down the cowl can make it into the fan assembly.
elsolo is offline
Old 02-16-2013, 06:47 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,435, Level 75
Points: 13,435, Level: 75 Points: 13,435, Level: 75 Points: 13,435, Level: 75
Level Up 47% Completed
Forum Activity 99%
And when mine was squeaking a bit, I put a couple drops of motor oil on the shaft between the fan & the motor so it could seep into that bushing. Can't reach the right spot, even with a proper oil can with a long spout, so I had to aim well for the last couple inches of reach.... (grin)
sailor is online now
Old 02-18-2013, 06:15 AM   #4
Cheif117
Fan#: 108702
See the fan what part of it are u meant to oil ? The top part of the fan thers a small nut thing which is rusted do I just put it on the top there ?
Cheif117 is offline
Old 02-18-2013, 06:21 AM   #5
KCaudill
Fan#: 46826
What I Drive: 2006 Tredour Red ZX3 SE
Points 334, Level 6
Points: 334, Level: 6 Points: 334, Level: 6 Points: 334, Level: 6
Level Up 68% Completed
FF Reputation: 1 KCaudill Good Standing Member
Repalce it, only $60 at autozone, 15 mins in and out
KCaudill is offline
Old 02-18-2013, 06:23 AM   #6
Cheif117
Fan#: 108702
The fan works perfectly its just the screeching noise driving me insane. Id rather make attempts to fix it lol
Cheif117 is offline
Old 02-18-2013, 11:32 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Oil on shaft BETWEEN fan & motor might help. Any on the rusty part mentioned won't help...
Old 02-18-2013, 02:04 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
You need to remove the plastic cover that hides he commutator, brushes, and end bearings. There are three rubber detents that need to be pushed in to pop the cover off.
elsolo is offline
Old 02-19-2013, 09:05 AM   #9
Cheif117
Fan#: 108702
How do u get the covr out ? Cant seem to push the rubber indents inside :(
Cheif117 is offline
Old 02-19-2013, 12:20 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
Once the fan motor is removed from the car:
There are three rubber detents that hold the cover on.
Stick a screwdriver or other tool in each of them to push the rubber "tab" in, you may want to use three tools at the same time.
elsolo is offline
