2012 Focus SE - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2013, 08:26 PM   #11
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,083, Level 69
Points: 11,083, Level: 69 Points: 11,083, Level: 69 Points: 11,083, Level: 69
Level Up 59% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
Here's what these cars sound like from a roll to 60, completely stock with K&N drop in and airbox lid off...
YouTube Video
Airbox lid is back on now, but it was fun for a quick video clip
SCT PRP FTMFW!
mellephants is offline
Old 02-18-2013, 08:37 PM   #12
mellephants
Fan#: 52400
Also I went down to the scale for some rough weight numbers with my daughter, myself, a full tank of gas, and three or four bags of stuff in the car.
All numbers in pounds, and the scale rounds to 20's.
Overall: 3260
Left: 1640
Right: 1580
Front: 1880
Rear: 1360
Front Left: 980
Front Right: 920
Rear Left: 700
Rear Right: 680
These numbers don't sum correctly, though. *shrug*
L+R = 3220
F + R = 3240
FL+FR+RL+RR=2600
SCT PRP FTMFW!
Old 02-18-2013, 11:22 PM   #13
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 05 Slowbaru Outback
FF Reputation: 2 Kevastator Good Standing Member
Sounds like a little racecar in the video!
College Yo
[Rally Revolution #7]
ASPECT Motorsports
Kevastator is offline
Old 02-19-2013, 03:01 PM   #14
mellephants
Fan#: 52400
I've begun audio system upgrades.
The battery-top fuse holder from my old car wouldn't fit nicely on under the battery box on the 2012, so I found a plain black plastic fuse holder on Amazon (coincidentally, Littelfuse is located next door to the building I work in).
Littelfuse 298900 ($12.76 on Amazon)
20130218_30D_IMG_0036 by mellephants, on Flickr
20130218_30D_IMG_0037 by mellephants, on Flickr
After reviewing the photos, I noticed the ring terminal on the left isn't seated nicely, so I went out and fixed it. I didn't re-take the pictures, though, because it was dark by then.
20130218_30D_IMG_0040 by mellephants, on Flickr
I just snuck a ring terminal under the OE battery strap, and tucked the 4 AWG into factory wiring channels.
20130218_30D_IMG_0041 by mellephants, on Flickr
20130218_30D_IMG_0042 by mellephants, on Flickr
I still haven't attached it very well, but it doesn't move around too much. I will probably 3M doublesided tape or velcro it to the fuse box lid, unless I think of some better place to hide it. At least it isn't translucent or bright red or anything.
20130218_30D_IMG_0045 by mellephants, on Flickr
20130218_30D_IMG_0052 by mellephants, on Flickr
To get the wiring into the car, I went through the fender/doorsill, then under the carpet on the driver's side. This is the only place the wire is visible, which I am not totally happy with, but it didn't require any modifications or cutting of anything. Instead of punching a hole in the factory grommet for this hole, I just removed it. I will source a replacement grommet to cut a hole in, so the original can be installed if the wire is removed later on.
20130218_30D_IMG_0044 by mellephants, on Flickr
SCT PRP FTMFW!
Old 02-19-2013, 03:15 PM   #15
mellephants
Fan#: 52400
Here's a quick picture of the head unit swap. I'm still not totally done with it, so it is just hanging in there with about 3/8 screws right now, because I don't like to overuse the plastic screw clips, but you get the idea.
Head unit swap parts list:
Metra 99-5827B
Metra XSVI-5524-NAV
Metra ASWC-1
Metra 40-EU10
IMG_20130216_100531_GNEX by mellephants, on Flickr
SCT PRP FTMFW!
Old 02-19-2013, 06:07 PM   #16
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,076, Level 50
Points: 6,076, Level: 50 Points: 6,076, Level: 50 Points: 6,076, Level: 50
Level Up 63% Completed
Forum Activity 2%
FF Reputation: 9 Deftmetal Good Standing Member
You should put a grommet around that wire in door jam. Don't want it to short out
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 02-19-2013, 07:50 PM   #17
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,276, Level 87
Points: 19,276, Level: 87 Points: 19,276, Level: 87 Points: 19,276, Level: 87
Level Up 86% Completed
Forum Activity 12%
FF Reputation: 7 badazz2010focus Good Standing Member
small piece of wire loom will cure that...that 4 gauge? any car audio shop will have loom.
badazz2010focus is offline
Old 02-19-2013, 11:02 PM   #18
2005sangriaZX3
2005sangriaZX3's Avatar
Fan#: 25773
What I Drive: 2004 Merc Grand Marquis
FF Reputation: 1 2005sangriaZX3 Good Standing Member
please, please run that power wire properly through the firewall with a proper grommet. That is an electrical fire waiting to happen. Car looks great though!
MECP Master Certified Autotech
Milwaukee, WI
2005sangriaZX3 is offline
Old 02-20-2013, 07:23 AM   #19
badazz2010focus
Fan#: 78166
Forum Activity 12%
yeah tell me about it, I'm sure theres a clutch pedal hole if he's automatic.
Old 02-20-2013, 09:33 AM   #20
mellephants
Fan#: 52400
That doorjamb location is fine. It is inspectable every time I enter the car, the insulation is in great condition, the wire cannot interfere with the hinges, the hole has smooth painted edges, and the wire is properly fused.
I have already stated ITT that I will source a grommet. In my experience, a piece of heater hose works better than plastic loom, if I can't find a grommet I like. I will also look a bit more for a firewall passthrough, just so the wire is hidden, but not for safety reasons. I really like this location for safety. There is no engine heat, no movement, no oil, no dirt, no salt, etc... which are all things a lot of installers will subject a wire to by using a hole low on the firewall - the clutch hole on an auto, for example, is normally a terrible spot for those reasons.
If anyone has found a nice spot which does not require slicing factory wiring looms or grommets or drilling new holes, and is high up on the firewall away from heat and contaminants, let me know.
SCT PRP FTMFW!
