DCT Revs and Speed question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2013, 09:04 AM   #1
nseah
Fan#: 101824
What I Drive: 2012 Sterling Grey Ford Focus SEL
FF Reputation: 1 nseah Good Standing Member
This is my first time with a DCT, my previous cars have been manuals. In a manual, when you engage the clutch in gear and push the gas the revs build as the speed builds. In my DCT focus, when it shifts into 3rd and 4th gear and the clutch engages (i'm continueously giving it gas) the revs seem to bounce a bit up and down at first as the speed increases. After maybe 1 or 2 seconds the clutch locks and the revs build as it should.
In a manual car this would be clutch slipping, but with a DCT i'm not sure if this is some sort of feature that makes the gear changes more smooth (i.e. slowly matching the revs with the speed). The ride is still smooth, but my concern is that doing this constantly would lead to faster clutch wearing no?
has anyone else noticed this in their car? should this be something I should be concerned about?
I also noticed that this only happens when im driving the car at a casual pace. If i'm really pushing the pedal the shifts are noticeable and the revs build as soon as the clutch locks (no bouncing around).
-Nate
2012 Sterling Grey Ford Focus SEL Hatchback
nseah is offline
Old 02-15-2013, 09:32 AM   #2
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Mine does the same thing. Ford mentions the concept of "microslip" in the DCT which I interpret as allowing the clutch to slip slightly make the experience a bit smoother. In some conditions, mine will even exhibit this behavior if gas is given suddenly when cruising, but not enough so as to cause a downshift.
Let's hope this is normal. Maybe the Ford rep could comment. Cory?
dan50 is offline
Old 02-15-2013, 09:44 AM   #3
nseah
Fan#: 101824
Hmm ok, well its good to hear others experiencing this and it's not just me. I figured it was some kind of feature to make the shifting smoother and more automatic-like. My thoughts are doing the slipping constantly over time will lead to faster wear.
-Nate
nseah is offline
Old 02-15-2013, 10:09 AM   #4
mp223
Fan#: 104161
What I Drive: 2012 Focus SEL
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 0 mp223 Newbie
I too have noticed the same behavior, "microslip." Details are sparse, but I would assume it's clutch slippage to make smoother shifts. Certainly that will wear the clutch down faster. I'm sure Ford has designed the transmission in such a way to last through the warranty period, but after that, who knows. Clutches are wear parts after all.
Also do not expect Cory or any Ford rep to comment. Cory isn't here to answer questions, just to escalate customer issues.
mp223 is offline
Old 02-15-2013, 10:57 AM   #5
Dysan911
Fan#: 95746
Im glad you brought this up. I've been meaning to do the same. I notice this behavior with highway on-ramps. I will get a rate of acceleration I'm comfortable with and hold that.. The Speed and RPM's seem to be climbing at a synchronized rate and then on 3rd gear or 4th.. Maybe both. Thats when the RPM side just hovers around 3k RPMish but the Speed is still rising so I assume if the clutch was slipping like it would in a traditional manual tranny my speed would be dropping off.
Like you, this behavior concerns me of clutches slipping and burning up. If I let up on the gas it seems to do this less and will just shift into 5th/6th.
I've never smelled burnt clutch so it must be by design. (at least that's what convinces me).
FWIW, My clutches were completely replaced a few months back due to a TSB involving leaking seals. Prior to getting the clutches replaced. My shifts were all over the place, never could find the right gear and made a horrible noise at some RPM's. After the new clutches, it's like a completely brand new car. No shifting problems except for just this strange slipping sensation.
I definitely hope it's supposed to do that and that I'm not looking at replacing clutches at 36k miles.
I firmly believe though that the DCT tranny will never see 100k miles without some major repairs. If it turns out the average life of the DCT transmission exceeds 100k. I'll be mighty impressed.
2012 FF Ti HB Platinum White Tricoat, Built 12/11, 401A + Parking Technology Package and MFT w/NAV at 3.5.1
Dysan911 is offline
Old 02-15-2013, 11:02 AM   #6
mark3inline
Fan#: 19701
What I Drive: 04 Wht ZTW
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 3 mark3inline Good Standing Member
Since this type of trans/engine management has been used in F1 for what the last 15 years. With drive by wire throttle, the ecu controls everything, air, fuel, ignition, clutch, and shifting. I undestand this isn't a million dollar control system but, Europe has been using this in the Focus two years before released here, didn't they learn anything from that ?
mark3inline is offline
Old 02-15-2013, 11:26 AM   #7
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
I thought this was my transmission clutch going out. I have the point where I accelerate, my rpm's go higher, but it doesn't down shift and tend to just sit there. Might be I hit the gas to hard but older cars has no problem with down shifting and such. Maybe I should get a new clutch before my warranty is up.
HoneyBadger is offline
Old 02-15-2013, 11:42 AM   #8
Kabigon
Fan#: 88299
Points 4,402, Level 42
Points: 4,402, Level: 42 Points: 4,402, Level: 42 Points: 4,402, Level: 42
Level Up 26% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 11 Kabigon Great Standing Member
F1 cars use a dual clutch transmission similar in operation to that of the Focus (and not a single clutch sequential transmission)?
Are you sure?
That's not how it works in the Focus. There is a separate PCM and TCM.
The first (and only other) application of the Focus DCT was in the Fiesta.
I am Kabigon and I approve this message.
Kabigon is offline
Old 02-15-2013, 11:51 AM   #9
Kabigon
Fan#: 88299
Forum Activity 15%
Are you referring to the clutches themselves?
I've read nothing to suggest that the "gearbox" itself is inherently unreliable.
Kabigon is offline
Old 02-15-2013, 01:50 PM   #10
dan50
Fan#: 91789
Forum Activity 4%
Agree. The gearbox itself should be very long-lived: if everything works right there are no missed shifts, no improper clutch action, no gear clashing, etc. The microslipping (if that's what we're experiencing) seems to occur when not a lot of torque is being transmitted, so I'm not that pessimistic about clutch life either.
dan50 is offline
