Help - 2.3 Low idle (750~) misfire/hesitation/stutter from idle - 2500~ - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2013, 03:38 AM   #1
Fangren
Fan#: 100337
What I Drive: 2003 Black Centennial ZTS 2.3l MTX
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
Level Up 90% Completed
FF Reputation: 1 Fangren Good Standing Member
I have a 2.3 Dtec with 177000 miles. 2 of 4 spark plugs i pulled had oil on threads + a metal flake/shaving.
I swapped in new plugs and it temporarily solved my issues.
But 20 miles later the issues are seemingly coming back.
I searched and saw that Piston rings, or even Coil packs would be culprits in causing my symptoms.
Anyone have similar issues and resolved them?
Im about to schedule a compression test to help seek an answer.
After 3100 rpm, engine runs fine and accelerates very nicely. Obviously though im not going to be in a constant state of hard acceleration.
Fangren is offline
Old 02-15-2013, 07:06 AM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Whats your regular maintenance schedule like?
Along with the plugs I would change the fuel filter if you haven't recently. A compression test would give you piece of mind. Oil on the threads of the plugs could mean you need a valve cover gasket change; easy to do in your driveway.
My 2.3L has 167k miles with 30k miles of 8 psi and still runs like clockwork.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 02-15-2013, 07:13 AM   #3
Fangren
Fan#: 100337
Points 295, Level 5
No schedule, car has been in my hands for 1 month being fixed from total worthy status to beater status. Ive driven it 125 miles so far :p
Fangren is offline
Old 02-15-2013, 07:56 AM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,875, Level 74
Points: 12,875, Level: 74 Points: 12,875, Level: 74 Points: 12,875, Level: 74
Level Up 7% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 02-15-2013, 08:36 AM   #5
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
Try cleaning your MAF and IAC. At 177K, new coil on plugs wouldnt hurt either.
GreySkorpion is offline
Old 02-15-2013, 08:52 AM   #6
Fangren
Fan#: 100337
Points 295, Level 5
Thank you Zetec, and sorry still bit new to acronyms, mass air flow and IAC is what? Ill pock up an electronic cleaner at work.
Fangren is offline
Old 02-15-2013, 01:29 PM   #7
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 468, Level 9
Points: 468, Level: 9 Points: 468, Level: 9 Points: 468, Level: 9
Level Up 36% Completed
FF Reputation: 1 drewts86 Good Standing Member
Oil on plugs - found the same thing on my girlfriend's Celica. All it needed was a new valve cover gasket; backs up what Jgrove said
drewts86 is offline
Old 02-15-2013, 08:39 PM   #8
GreySkorpion
Fan#: 94674
IAC, Idle Air Control, its on the throttle body and can get gummed up. It has a plunger on a cylinder. Worth a shot. Also a valve cover gasket as mentioned cant hurt.
Old 02-16-2013, 01:35 AM   #9
Fangren
Fan#: 100337
Points 295, Level 5
Thank you for the advice. Ill clean it out asap. Its been running better since just the plug swap alone. But not perfectly. Ill locate a gasket/coils and do a all in one clean up. Bought a can of seafoam just in case to clean up the engine internally. Figured it wouldnt hurt to give it a once over on all bases.
As for fuel filter, another good point, I have to replace my Power steering pressure line so once i get the car on a lift ill fish that out as well. Thankfully i have my 2000 lx (SPI) DD that i can put my registration back on if i cant get this zts Centennial (Dtec) on its feet before the inspection is due.
To pass inspection it needs the power steering line + parking brake adjuster bars. Not much but im hoping to JY the adjuster bars to avoid 140 in dealer parts + the 60~80 Power steering line.
Fangren is offline
Old 02-28-2013, 03:29 AM   #10
Fangren
Fan#: 100337
Points 295, Level 5
Further Note, Issues still abound, Replaced 4 Motorcraft plugs, cleaned MAF sensor and ran Lucasoil to clean out injectors etc. Going to find out and clean theIAC next and try and research the vacuum lines. Anyone know diagrams?
Fangren is offline
