hey yall, help please - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-14-2013, 10:24 PM   #1
RedRiderr13
RedRiderr13's Avatar
Fan#: 98089
What I Drive: 2005 maroon zx5
FF Reputation: 1 RedRiderr13 Good Standing Member
hi guys i started a tread a while back, but i need help again cuz im at a wall.
my car got an engine swap, 2.0 for 2.0, and it is throwing a code for "system lean blank" i figured this was a vacume leak someplace, but i cannot find the leak anywhere, would a bad maf sensor be a cause of this? the main issue is that when im cruising the freeway and light on the pedal, the temp guage rises rapidly, so i cannot drive far. what else could be going wrong that im missing, has anyone here experienced anything like this before? thanks in advance.
RedRiderr13 is offline
Old 02-14-2013, 10:28 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,343, Level 100
Points: 138,343, Level: 100 Points: 138,343, Level: 100 Points: 138,343, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Moved to Technical chat
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 02-14-2013, 11:29 PM   #3
RedRiderr13
Fan#: 98089
my bad, its been a while.
Old 02-14-2013, 11:47 PM   #4
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Buy-Sell-Trade Rating: (6)
did you replace your thermostat? Also Maybe the CHT sensor.
P0171 If there is no vacuum leak or the pcv hose isnt collapsed that attaches to the manifold then i would be very positive that the MAF is bad.
Squareleft is offline
Old 02-15-2013, 12:05 AM   #5
RedRiderr13
Fan#: 98089
the thermostat was replaced by the people that did the engine swap, but im thinking of trying to put another in and see what the issue was.
this is the code i got and the discription for it:
P0171 - System too Lean (Bank 1)
The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
Old 02-15-2013, 12:43 AM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
A more detailed description with possible causes:
Possible causes for lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
BC_ZX3 is offline
Old 02-15-2013, 01:04 AM   #7
Squareleft
Squareleft's Avatar
Fan#: 33224
most common causes are the maf and vacuum leaks.
Old 02-15-2013, 01:28 AM   #8
RedRiderr13
Fan#: 98089
i guess ill start going thru everything tomoro, starting with maf, i have already searched for vac leaks. thanks again, anyone with any other ideas, please let me know.
Old 02-16-2013, 08:04 PM   #9
RedRiderr13
Fan#: 98089
ok, so i changed the MAF sensor, the check engine light is gone now. BUT the car is still doing the whole running hot thing when on the freeway, no what should i look to change out? im thinking the coolent temp sensor,(anyone know where this is??) thanks in advance.
Old 02-16-2013, 10:30 PM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 54%
Maybe they put the t-stat in backwards?
Moderator for
Technical Chat
