Broken hose. IAC? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2013, 04:46 PM   #1
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 530, Level 10
Points: 530, Level: 10 Points: 530, Level: 10 Points: 530, Level: 10
Level Up 60% Completed
FF Reputation: 1 drewts86 Good Standing Member
Broken hose. IAC?
Need some help IDing this part. I'm guessing this is what set off my CEL, and I'm assuming this is part of the IAC system?
drewts86 is offline
Old 02-13-2013, 05:12 PM   #2
zpellicone
Fan#: 105007
What I Drive: 2001 Pitch Black ZTS
FF Reputation: 1 zpellicone Good Standing Member
Do't quote me on this because my experience is solely with the zetec, not duratec, but it looks very similar to the PCV hose on my engine. They are prone to collapsing as well as splitting down near the pcv valve itself on zetecs. The diameter and hose type seem similar. But i guess you would probably be experiencing rough idle issues if that was the case
zpellicone is offline
Old 02-14-2013, 01:42 PM   #3
drewts86
Fan#: 72974
Bump. Lookin for a solid answer. PCV is what I'm hearing from a Zetec man, just want to confirm from a Duratec owner...
drewts86 is offline
Old 02-16-2013, 04:33 PM   #4
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
The part that your index finger points to in the second picture is a vacuum solenoid valve. You can see that the nipple is broken off along with the hose. There are two of these mounted on top of the intake manifold. On my Duratec engine, one controls manifold vacuum going to the actuator for the Swirl Control Valve(s) (SCV) in the intake, the other valve controls manifold vacuum going to the actuator for the Variable Inlet System (VIS) valve(s) also in the intake. Yes, the break shown in the picture will set a CEL. You need a new vacuum solenoid valve. The repair should be simple although the part may be dealer only. The destination of those vacuum hoses will be shown on the emissions sticker located on the underside of your hood.
For a temporary fix, plug the end of the hose shown in your hand with a golf tee. Good luck and let the forum know whatever your fix turns out to be. That way the forum knowledge base is increased.
2001 Amazon Green ZTS 100,000mis
2012 Sterling Grey SE Sedan M/T!
drjkel is offline
Old 02-16-2013, 04:44 PM   #5
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,703, Level 94
Points: 23,703, Level: 94 Points: 23,703, Level: 94 Points: 23,703, Level: 94
Level Up 36% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
^^ this. the pcv valve and hose on a duratec is tucked nice and deep behind the intake manifold.
mikebontoft is online now
Old 02-16-2013, 07:52 PM   #6
drewts86
Fan#: 72974
Thank you gentlemen, you've been a big help. Now - once I can get over this pneumonia I'm gonna see if I can deal with this issue.
Cheers,
Drew
drewts86 is offline
