Exedy OEM Replacement Clutches - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2013, 04:22 PM   #1
defektes
Fan#: 84501
What I Drive: 2001 Black ZTS
FF Reputation: 3 defektes Good Standing Member
Hey guys, its clutch changing season again for my 01 Zetec.
The last clutch I installed was a Perfection Clutch pack from NAPA. It has got 79k miles and is starting to slip. The original went 82k.
I was eyeballing a Exedy OEM clutch pack from Amazon for 139 US. That is a hell of a deal.
Anyone used a exedy kit? How do they hold?
I can get a Sachs which I know is what came with the car for 204 US.
Is the exedy worth the money savings?
Update from dealer:
Service advisor received a letter from Ford corp "engineer". Letter "email" states no reverse is from motor swap install. Ford engineer recommends putting original motor back in.
defektes is offline
Old 02-13-2013, 06:08 PM   #2
mark3inline
Fan#: 19701
What I Drive: 04 Wht ZTW
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 3 mark3inline Good Standing Member
If you want a longer lasting unit. you have to go HD (heavy duty) or stage 1. the clutch feel will be a little diferent because of the spring force in the pressure plate, it will hook up better and last longer.
mark3inline is offline
Old 02-13-2013, 06:23 PM   #3
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
If you want a long lasting clutch, OEM is the way to go. Aftermarket performance clutches just don't have the same life span as a stock clutch.
Not sure about with the focus but I don't believe Exedy holds up at all in the Contour.
Also, if your clutch is only lasting 80k, I would look into how its being driven. My 95 Mystique w/Zetec had the original clutch at 228k when I sold the car, it has over 250k on it now. And even if it wasn't orginal I put 142k miles on it over 10 years.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 02-13-2013, 10:36 PM   #4
defektes
Fan#: 84501
It is a multi user car, and I dont particularly baby it. Im assuming that is why they are only lasting so little.
I do my own clutch jobs so its not that big of a deal to replace often but if OEM will outlive a aftermarket I am willing to try.
Update from dealer:
defektes is offline
Old 02-14-2013, 04:24 PM   #5
mark3inline
Fan#: 19701
Points 217, Level 4
Heavy duty , more abuse or use. Ford like most OEM's put in the cheapest parts they can find or make. The disk material is still organic, but the pressure plate has a larger clamping force, so less slip, less wear on friction plate, pressure plate, and flywheel. Exedy knows their stuff, but alot of their parts can only be used with their parts, clutches with flywheels.
Old 02-14-2013, 04:49 PM   #6
Budderybunz
Budderybunz's Avatar
Fan#: 107821
What I Drive: 2004 SVT Turbo
FF Reputation: 1 Budderybunz Good Standing Member
I really like my exedy oem clutch, and my car is putting down 230whp daily.
2004 Screaming Yellow SVT Turbo
Budderybunz is offline
