dead SPI engine, need to find the problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2013, 12:41 AM   #1
jiangfsh
Fan#: 109856
What I Drive: Focus 2002, SPI, Gold
FF Reputation: 1 jiangfsh Good Standing Member
My focus was running rough and pepboys recommend to replace all three engine mount. I prepare to DIY it. After I received them from Ebay, the engine light is on showing the fourth cylinder misfire P0304.
And after two days, there's loud noise when start and then the engine dead after several try. I found the spark plug is broke in the fourth cylinder which filled with coolant. Is that the same problem with the valve? thanks.
As a new member, I don't know why the coolant can enter the cylinder.
jiangfsh is offline
Old 02-13-2013, 12:42 AM   #2
jiangfsh
Fan#: 109856
I just received the engine hoist today. I'm happy to join the dead SPI engine club.
jiangfsh is offline
Old 02-13-2013, 08:24 AM   #3
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
Add yourself to the list of a dropped valve seat in #4, pull the head off, the light end of it you need a new head as yours was smashed up allowing coolant to come into the cyl from the head, worst case is you need a new block as its cracked. Wont know till you remove the head. I have good used pistons and rods if you dont need a block. Likely all your pistons will have damage which in return bent your rods.
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
