Go Back   Focus Fanatics > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 02-12-2013, 08:52 AM   #1
Deeprecon1
Fan#: 109780
What I Drive: 2013 silver se 5 speed & 04 F250SD
FF Reputation: 1 Deeprecon1 Good Standing Member
5th gear swap out need some help ! 2013 se 5spd
Anyone have source info on where to buy Tranny parts ?
? Why, I am going to change 5th gear in my SE. 3200rpm at 70 is horrible. I travel daily 100 miles round trip, most of the time at 65 mph plus. 31 mpg is a joke. If I recall correctly 5th gear ratio is some where in the .8 it needs to be low .7 IMHO .. Shame on me for not doing better research before this purchase
Edit found it !
Standard Five-speed manual
Gear ratios
First 3.67
Second 2.14
Third 1.45
Fourth 1.03
Fifth .81
Optional PowerShift six-speed automatic
Gear ratios
First 3.917
Second 2.429
Third 1.436
Fourth 1.021
Fifth 0.867
Sixth 0.702
Reverse 3.507
Fourth 1.03
Fifth 0.81
Deeprecon1 is offline
Fan#: 1
Old 02-12-2013, 09:38 AM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
FF Reputation: 6 Magus2727 Good Standing Member
So your wanting to swap out your manual with the automatic? I am 99% sure you cant just swap out the gears. Auto and Manual transmission work very differently.
31 MPG is not bad... did you not read the sticker on the car to see what the freeway MPG is? I think its around 36 on your vehicle (With Auto)... not sure how that changes with the use of the manual. You will be better off using cruse control more often, driving during non peak travel times, get skinny tires, and make sure you have correct tire pressure.
Edit: putting your information in you should be more at a 2600 RPM @ 65 MPH in 5th gear. and changing out to a lower gear would put you at 2350 RPM. I am not sure if a change of 250 RPM's is going to give you the expected MPG improvement you may want.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 02-12-2013, 09:38 AM   #3
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
FF Reputation: 5 RonMaiden Good Standing Member
beware,I wouldn't do anything that's going to throw the warranty out on the whole drivetrain especially with the track record the MK3s have been having.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is online now
Old 02-12-2013, 09:50 AM   #4
Deeprecon1
Fan#: 109780
Highway 36 for the manual, sticker is in front of me. The sticker on the Auto is 38 highway
No I am not going to try and swap out the gears from a auto box.
I am trying to source a .7 ish gear for a swap, I guess I was not clear in my request.
Warranty ... I will be done with my warranty in 1.5 years.
31mpg at 65mph for 30 miles CC on ! I was just happy to see the display read over 30 mpg for the first time this morning.
Old 02-12-2013, 10:05 AM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Winter gas IIRC usually also has a slight decrees in fuel economy due to additives to keep it from freezing. You also may have the defroster on, or snow or other items on your car that increases drag?
You will be spending $$$ on a gear... they made a different gear for the MTX-75 transmission but was a higher final drive of a 4.06 gear.
I looked at one time offsetting that with a lower 5th gear but it was going to be all custom. and gears are a costly manufacture for a 1 off deal.
There is the little * next to the expected MPG right? Have you checked the tire pressure lately?
Hatch Nation #42
Old 02-12-2013, 10:08 AM   #6
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
FF Reputation: 2 Brabs_Weather Good Standing Member
Why not swap to a 6speed from a Mazdaspeed3. Cobb mated it up in the SEMA Focus. The link below is the ST transmission specs.
http://www.focusst.org/forum/focus-s...ion-specs.html
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
Injen SRI Intake. Steeda RSB
Brabs_Weather is offline
Old 02-12-2013, 10:13 AM   #7
Deeprecon1
Fan#: 109780
I live in central California, the low temps in the am are Norm above 40f. Single gears cost in the 400-500 range. I am assuming here but I bet the euro version have a better gear ratio.
MY focus has less than 500 miles on it. All tires are at spec checked last night when cold.
For the record I am a former vwTDI gear head. 47mpg with a tune, I know this is not a TDI nor will I get near the mileage.
Old 02-12-2013, 10:29 AM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Is it typical to see lower fuel economy on the first few hundred miles or so because of engine brake in?
Also (http://www.fueleconomy.gov/feg/Power...WD&srchtyp=ymm) shows that 29 is about average.
so gear $400-$500 + a few hundred to install. so your at $700 to get the gear and installed.
to increase you to perhaps 35-36 MPG? vs 30MPG , 6 MPG difference. @ $4.00 a gallon you would need 175 gallons of fuel saved before you brake even. A difference of 6 miles per gallon you would need to travel approx 31,500 miles before even braking even.
People have seen a difference of about 200-300 RPMS when swapped to the 4.06 gears so you are likely to see less than the 6 MPG difference with a change from .82 to .7. which will take longer to brake even. If you drive that much and will have the car that long then go for it~!
Hatch Nation #42
Old 02-12-2013, 10:35 AM   #9
RonMaiden
RonMaiden's Avatar
Fan#: 99230
I love math and stats;you go Magus.
Old 02-12-2013, 10:39 AM   #10
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
FF Reputation: 1 BrApple Good Standing Member
well there it is. You need to get some miles on the car and let it break in. I saw continued improvements in mpg as the miles added up. Yes they have dropped recently but its winter ....
My wife drove my 2012 SE w/5-spd once at 65 mph and the tank ended up being nearly 40 mpg.
Also, imho, the gearing is where one wants it to be with the power this engine makes.
Also you don't just change one gear. If you want to drop the rpm you make a final gear ratio change. The mtx-75 had at least 3 gear ratios. The only time I have heard of people changing the gear ratio are Contour owners with 3l engine swaps and often forced induction. IIRC going from the 4.06 in the Contour to the Focus/Zetec ratio of 3.8 dropped about 500 rpm.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
