Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 02-12-2013, 08:42 AM   #1
nerdrage
nerdrage's Avatar
Fan#: 100392
What I Drive: 2012 Focus SEL Ingot Silver
FF Reputation: 1 nerdrage Good Standing Member
Exclamation Horrible Noise from Rear of Focus
I'll start this off by saying I love my 2012 focus hatchback sel. However its going in to the shop today for the 2nd issue Ive had since buying it in June 2012.
First issue was the tail light being attached too tight and actually scratching the paint. Ford replaced the taillight it still doesnt fit correctly but its not hurting the paint.
Now its going in because the rear of the car sounds like its going to bounce off. Whenever starting to accelerate, coming to a stop or going over bumps. There is a horrible screeching noise. It sounds like its bouncing apart. Im hoping it can be fixed.
Just in case does anyone have the address for Ford to send letters or contact someone in regards to this. Im trying to start documentation in case they cannot fix it to lemon law the car. I hope they fix it but this noise is far from normal.
nerdrage is offline
Fan#: 1
Old 02-12-2013, 08:51 AM   #2
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
FF Reputation: 6 dan50 Good Standing Member
I wouldn't start thinking about Lemon Laws quite yet. This sounds like an easy diagnosis and fix, particularly if the noise occurs consistently. It could be something as simple as an exhaust system that needs to be adjusted or rehung.
If your visit to the dealer isn't successful one of the Ford moderators on this board can probably help. IIRC, Ford addresses and customer service numbers are in the Owner's Maual.
dan50 is offline
Old 02-12-2013, 08:59 AM   #3
nerdrage
nerdrage's Avatar
Fan#: 100392
Its something with the springs or shocks. Im worried after so many of the frunt strut noise threads it will be passed off as normal. Im just covering myself. again i hope they fix it but just in case. thanks ill check my manual for the address.
It seriously sounds like the rear of my car is bouncing off.
nerdrage is offline
Old 02-12-2013, 11:24 AM   #4
nerdrage
nerdrage's Avatar
Fan#: 100392
Well Gene Latta Ford has said they can do nothing. My Steeda Rear Sway bar voided my warranty they say
nerdrage is offline
Old 02-12-2013, 01:07 PM   #5
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
FF Reputation: 7 BetaDnB Good Standing Member
Have you tried greasing the bushings on your sway bar? That's something you should've mentioned in your first post.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 02-12-2013, 01:18 PM   #6
nerdrage
nerdrage's Avatar
Fan#: 100392
i greased the hell out of them when i installed it 10k miles ago.
nerdrage is offline
Old 02-12-2013, 01:23 PM   #7
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Since you're not going to get any help from Ford I would suggest you either remove and reinstall the stock bar and bushings or remove the Steeda and regrease and reinstall. PITA, I know.
BetaDnB is offline
Old 02-13-2013, 02:53 PM   #8
Pendarus
Pendarus's Avatar
Fan#: 94411
What I Drive: 2012 Sonic Blue Titanium 5dr
FF Reputation: 2 Pendarus Good Standing Member
I will bet it's loose end links on the rear sway bar. Check all the bolts with a torque wrench, don't trust they are tight, make sure they are torqued to spec..
Sonic Blue Titanium 5dr Titanium Handling Package
Ordered: 01/28/12
Vin: 02/20/12
Build Date: 03/06/12
Delivery Date: 03/30/12
Pendarus is offline
Old 02-13-2013, 03:05 PM   #9
nerdrage
nerdrage's Avatar
Fan#: 100392
Sorry didnt update this. I loosened my Steeda sway bar and retightened it to spec. Screech is gone.
Couldnt believe it was the bar. Looking at it everything looked ok, but who knows. Weve had some wicked could weather maybe it got loose since i installed it last summer.
nerdrage is offline
Old 02-13-2013, 03:29 PM   #10
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
FF Reputation: 3 sgmfocus Good Standing Member
mistake
sgmfocus is offline
