04 instrument cluster flashes then goes out. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > SVT Interior Mods & Upgrades
SVT Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2002-204 SVT Focus.
Old 02-12-2013, 01:57 AM   #1
Sampsonite
Sampsonite's Avatar
Fan#: 79339
What I Drive: 2004 Black EAP SVT 5dr
Points 253, Level 5
Points: 253, Level: 5 Points: 253, Level: 5 Points: 253, Level: 5
Level Up 6% Completed
FF Reputation: 1 Sampsonite Good Standing Member
I have had this issue since I have had the car. My instrument cluster will flash in and out then eventually go out for a long time. Eventually it will com back on but goes right back out. The needles still have a glow but its the green glow that goes out. This also happens in sync with my oil press and oil temp gauge doing the same. Any idea's?????
Sampsonite is offline
Old 02-12-2013, 12:01 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,157, Level 74
Points: 13,157, Level: 74 Points: 13,157, Level: 74 Points: 13,157, Level: 74
Level Up 77% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
Old 06-27-2013, 01:14 AM   #3
Sampsonite
Sampsonite's Avatar
Fan#: 79339
Points 253, Level 5
Still looking for a solution.
Old 03-24-2014, 03:09 AM   #4
VAfromMN
Fan#: 20592
What I Drive: '13 Focus ST & '04 Focus SVT
Points 1,027, Level 17
Points: 1,027, Level: 17 Points: 1,027, Level: 17 Points: 1,027, Level: 17
Level Up 27% Completed
FF Reputation: 9 VAfromMN Good Standing Member
I'm having the same problem with mine, and I believe it's only the SVT's that have the electroluminescent lighting. If you search the Forums for the EL/electroluminescent lighting you should find reference to an inverter that lives in the small SVT oil temp/oil pressure cluster. That's what's slowly dying. One person did have a workaround with a replacement inverter from a home entertainment system I think. Did you ever find a solution?
VAfromMN is offline
Old 03-24-2014, 03:15 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,417, Level 75
Points: 13,417, Level: 75 Points: 13,417, Level: 75 Points: 13,417, Level: 75
Level Up 42% Completed
Forum Activity 99%
Moved this to the SVT section, 'cause you can find more info. here on fixing it.
You could look in the MkI section as well, for info. on installing the SVT cluster in other cars. Those threads sometimes list the inverters that can be used to power the lights.
Last post had it right on the power coming from the gauge cluster from the info. I've found here before.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-24-2014, 03:53 PM   #6
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,130, Level 27
Points: 2,130, Level: 27 Points: 2,130, Level: 27 Points: 2,130, Level: 27
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
You can use any universal inverter like this.
http://www.ebay.com/itm/UNIVERSAL-EL...fe16e9&vxp=mtr
Sniper Focus is offline
Old 03-24-2014, 03:56 PM   #7
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
FF Reputation: 1 ShadowFocus603 Good Standing Member
I tried replacing my headlight switch which was the common answer I found all over and it worked for awhile but started acting up again. From what I have read there is an inverter or some such in the cluster up by the 2 auxiliary gauges that can be replaced as well though I haven't tried that yet. My car also has a tachometer that intermittently pegs up and down and jumps around. Both problems only occur when the car has been running for awhile (~30 minutes or more) so I am fairly certain the issues are caused by some unknown as of yet electrical component that glitches after it gets hot.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
Old 03-27-2014, 11:24 PM   #8
Ptreezx3
Ptreezx3's Avatar
Fan#: 97773
What I Drive: 2003 red svt, 06 blue escape,
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
FF Reputation: 1 Ptreezx3 Good Standing Member
Its your aux gauge either needs replaced or universal inverter. Mine hsd same issue and this site told me it was that and when I replaced aux gauge problem solved
Ptreezx3 is offline
Old 03-28-2014, 05:33 AM   #9
ShadowFocus603
Fan#: 118448
When you say Aux gauge are you talking about the oil temp and pressure gauges in the corner of the cluster or?
Old 03-28-2014, 08:26 AM   #10
Ptreezx3
Ptreezx3's Avatar
Fan#: 97773
Points 63, Level 1
Yea. The inverter is in the small gauge cluster. Thats what goes bad in it and without it no indiglow gauges
Ptreezx3 is offline
