HELP: My '06 started turning itself off while driving - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: What do you think is the cause?
Time to get a new ECU/custom tune! 0 0%
Swap out the fuel pump for sure! 0 0%
Faulty cam sensor? 0 0%
Alternator must be going out! 0 0%
Voters: 0. You may not vote on this poll
Old 02-11-2013, 11:16 PM   #1
Lumadar
Lumadar's Avatar
Fan#: 10555
What I Drive: 2006 Focus ZX3 SE Infra Red
FF Reputation: 2 Lumadar Good Standing Member
Exclamation HELP: My '06 started turning itself off while driving
My car is: 2006 2.0 manual. Stock ECU, added DIY intake (been on for 5+ years, but was recently professionally cleaned) and JUST added SVT/Borla exhaust. Engine stock otherwise.
WHAT HAPPENED:
When it rains it pours, I guess. I just took my car in to have my power steering pump replaced, SVT Borla Ford Racing exhaust installed, both front struts swapped and a 4-wheel alignment...and 5 days later while driving to work my car turned off while accelerating in 3rd gear around 45 mph.
The gauges and headlights stayed on, but 100% engine power off. Car started right back up and finished the .5 mile to work. This happened after about 23 miles of mostly highway driving.
Same day, I left work and drove about 1 mile and while sitting in neutral at a light it did it again. Started back up and drove home fine. Drove twice over the weekend no problem, but today when I went to go home from work it stalled out while downshifting 3-2 omw up to a light.
WHAT I HAVE TRIED: I had the full electrical system tested at NAPA and it came back fine. I have done this before as I have always had a problem since the car was brand new in 2006 where it intermittently will not turnover on my first attempt, but always does on the second try.
No one has ever been able to find a problem.
POSSIBLE PROBLEMS?
I have had it suggested that it could be the alternator, the ECU or possibly the fuel pump. I THINK when the engine cuts out the rpms drop to zero fairly rapidly, but I can't be positive as I am usually struggling to maintain control and get it restarted.
Anyone ever come across this?
2011 FORD FIESTA!
2006 Focus ZX3 SE Red
Lumadar is offline
Old 02-11-2013, 11:21 PM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Is the check engine light on? When Napa did the electrical test, did they also check the alternator?
jetrinka is offline
Old 02-11-2013, 11:47 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moving this to "General Technical Chat". I don't think you seriously need a poll. There could be a multitude of problems that could be causing this. Does the CEL come on when this happens? Are you having it checked for codes?
zetecDon is online now
Old 02-12-2013, 12:00 AM   #4
Lumadar
Lumadar's Avatar
Fan#: 10555
CEL, battery light and one other come on when the engine shuts down, but once I restart it they all go away and do not return.
The electrical test at NAPA goes through the battery but does test load and alternator readings. Everything came out perfect.
I have not had codes pulled. That was next on the list to try.
As for the poll, I know it isn't "necessary" but I didn't think it would hurt? Might be nice to see what is most popular...
2011 FORD FIESTA!
Lumadar is offline
Old 02-12-2013, 08:47 PM   #5
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 VillageT Good Standing Member
This sounds like it could be the fuel pump relay. Its in the electrical box under the hood (In my 2005 its #12). These are inexpensive and easy to replace. Try it before you spend a bunch of money you may not need to. This is a fairly common problem.
VillageT is offline
