boosting my zx3 - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2013, 02:38 AM   #21
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
Originally Posted by ZXthrizzle05 View Post
that's a 48mm inducer and 54mm exducer, quick spool no water needed good price and very reliable, make sure even with journal bearing turbos to use a restrictor
I've never ran a restrictor with my journal bearing precision turbos
turbosvtfocus04 is offline
Old 02-19-2013, 12:09 AM   #22
focused0713
Fan#: 105658
What I Drive: 2001 yellow zx3
FF Reputation: 1 focused0713 Good Standing Member
Spa manifold t3 flange and the precision 48 mm t3 work well together? Also im hearing alot of peoplesaying not to run restrictors with the journal turbos...kills their life? Any suggestions?
focused0713 is offline
Old 02-19-2013, 12:24 AM   #23
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
run a restrictor with any turbo. journal or ball bearing. to much oil pres will blow passed the seals eventually. its not a hard thing to add on. heres mine...
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 02-19-2013, 12:33 AM   #24
focused0713
Fan#: 105658
Where can i buy the restrictor? Also where can i buy fittings for my wastegate..it didn't come with any and in not sure what 2 buy? Its a spa 3 bolt 35mm
Old 02-19-2013, 12:41 AM   #25
focused0713
Fan#: 105658
My feed line has restriction built into the fitting, will that work or do i need a different restrictor?
Old 02-19-2013, 01:04 AM   #26
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
Did precision tell you to run a restrictor?
Old 02-19-2013, 10:37 AM   #27
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,172, Level 91
Points: 21,172, Level: 91 Points: 21,172, Level: 91 Points: 21,172, Level: 91
Level Up 65% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
if you have around 65-70psi oil pressure at cold start, -3an feed, -10an return routed correctly then you should not need a oil restrictor on a journal bearing turbo. a journal bearing turbo works just like crank and rod bearings in an engine and uses oil pressure to form a film for the shaft to float on and not contact the bearings. if there is to little pressure and the shaft contacts the bearing it will damage it. if you are getting oil blow by the seals on a journal bearing turbo there is probably another problem. i believe precision uses and internal restrictor on their bb turbos so they are not required on them either but i'm not sure about that.
Tim
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 02-19-2013, 10:43 AM   #28
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Correct is internal in DBB, some people in the past had issues blowing seals in either one and as a precaution PTE suggested to some to run restrictors but not to the limit just enough to lower the pressure on high flow pumps, since then they have corrected the design and even the DBB is a different seal.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 02-19-2013, 10:47 AM   #29
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
On my journal bearing precision turbos I've never ran a restrictor both my 4431 and 6266. I've even asked precision web I bought my turbo if I needed to run anything with the oil feed line and they said no.
Old 02-19-2013, 12:34 PM   #30
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
.065 restricter on Journal bearing, end of story it allows approx 50PSI of oil into the turbo which Journal bearings only need 45psi
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
