General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#11 | ||||
TURBO ZX3
FF MODERATOR RISE AGAIN EGGYOLK130 WHP 124 WTQ ZETEC CREW #271 RIFF CREW TURBO DYNO COMING SOON |
#12 | ||||
TURBO ZX3
that's a 48mm inducer and 54mm exducer, quick spool no water needed good price and very reliable, make sure even with journal bearing turbos to use a restrictor
#13 | ||||
How does the tune work?? Is it mailorder? Like i said in new at this and i am tryin 2 figure all this out on my own pretty much...not 2 many people here have focus knowledge so this is all i got..do u pay 1 price or every step..this is also my daily driver so will my car be functional during this process
#15 | ||||
TURBO ZX3
no its all through e mail with datalogs with your laptop. tom will take over your computer the first time to walk you through so that eerytime after that it will be a piece of cake, a pcv delete is a must just with going turbo, no matter the manifold. and the restrictor size for journal bearing is .065
#16 | ||||
Fins Up!
stock pump and bap will support around 350whp
stock zetec engine is good for about 220-250whp reliably boost will be around 10-15psi depending on how efficient your set up is tom's tune will not disappoint, he knows what he's doing precision turbos are a good turbo and are about as cheap as you can get a good turbo. to bad your doing your turbo set up now cause in a few months i'll have a kit out that would have saved you time and money pcv delete is not necessary for boost. it is best to delete it and run a breather can but a simple catch can to keep oil out of the intake will work. however i do not know that it will fit with the spa manifold anyway Tim
Turbo Turtle Garage facebook.com/turboturtlefabrication TurboTurtleFab@gmail.com |
#17 | ||||
TURBO ZX3
The plate will touch the turbo and cause irritating smoke
#18 | ||||
Miles don't matter as long as its been well maintained.
SVT: Topmount GT3582R, SAE ? Whp ? Tq, Built motor, stock head, new #'s coming soon ;) ZX3: RACE GAS 602whp 501tq Pump Gas SAE 454whp Garrett GT3582r, Topmount, built motor, Ported head, both Tuned by Fernando@RacingPartsSolution |
#19 | ||||
t(-_-t)
HKS||Garrett||TopSpeed||Tial||Massive|| |
#20 | ||||
Fins Up!
the 255 pump was not designed to be used with a returnless system like the focus uses. you have to switch to return style if you going with a pump like that. a pump like the 255 was designed to work with steady voltage. i didnt design them so im not sure of the reason but if you use it the gears inside the pump will wear out fast and it will fail. there is a high flow pump that works with a returnless system but i have not seen any one use it with the focus, its pretty expensive and most people that are going for over 350whp just switch to a return system
Tim
| Thread Tools | |
| Display Modes | |
