2012 ford focus which size tire will fit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-11-2013, 10:58 AM   #1
lildiup
Fan#: 109783
What I Drive: 2012 blue focus
FF Reputation: 1 lildiup Good Standing Member
Hey i have a 2012 ford focus and have 17" rims, was wondering if 225-45-17 would fit. i have 215-45-17 on it now i think.
lildiup is offline
Old 02-11-2013, 11:06 AM   #2
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
They'll be a little wider, and a little taller, but should fit fine. Adding a taller sidewall will cause our speedo to read a little slow and MPG may go down a bit. Since the taller tire affects final drive gearing, it may be a bit slower 0-60. It'll soak up bumps a little better as well.
cbdallas is offline
Old 02-22-2013, 11:53 AM   #3
hixsonaf
Fan#: 105317
What I Drive: 2012, White, SE Sedan
Points 341, Level 6
Points: 341, Level: 6 Points: 341, Level: 6 Points: 341, Level: 6
Level Up 82% Completed
FF Reputation: 1 hixsonaf Good Standing Member
225/45R17 will fit within your fender well. Even a full compression of the suspension they won't rub. I'm running 235/45/17 Falkens on the black Ford wheels with the machined lip. The OEM call out size for the 17" wheel option is showing up as a 215/50R17. Comparing that size to the 225/45R17 looks like this:
Your 225's will be
-0.24" on sidewall height
+0.4" on section width
-0.49" on overall diameter
-1.55" on circumference
+15.6 revolutions per mile
Allow +/- 0.2" for differences in brands specific sizes (as in they are listed as a size but may be a hair larger or smaller for reasons like steel banding or tread design, etc)
According to the given numbers above if your speedometer reads 65 mph your actual speed will be 63.74
This is the link to Discount Tire's size calculator, http://www.discounttire.com/dtcs/infoTireMath.dos
Always a good bookmark to have for us gearheads.
hixsonaf is offline
