Surfaced Head and Adjustable Cam Gears - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-10-2013, 07:38 PM   #1
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
FF Reputation: 1 sdaddy Good Standing Member
My head has had 0.040" taken off. In timing the cams today, it looks like there is about 5 degrees difference at the cam (about the delta between high and low point in the sprocket) due to the lower height.
Does this sound about right to you?
sdaddy is offline
Old 02-10-2013, 09:04 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,384, Level 61
Points: 8,384, Level: 61 Points: 8,384, Level: 61 Points: 8,384, Level: 61
Level Up 78% Completed
Forum Activity 36%
Activity: 36% Activity: 36% Activity: 36%
Not sure I am understanding your post. 0.040" off the head is almost indistinguishable when installed. Your tension / idle pulley will make up for the fact that your cams are now 0.040" closer to the crank shaft.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 02-10-2013, 09:38 PM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
right, that is not a lot at all infact that's a good mill also when cleaning the matte surface
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 02-10-2013, 09:39 PM   #4
sdaddy
sdaddy's Avatar
Fan#: 105173
Yes, the tension pulley will take up the "slack" from the left hand side (when looking from the front of the engine) but that in turn throws off the cam timing....
sdaddy is offline
Old 02-10-2013, 10:27 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 36%
Your timing belt will likely have more flex and adjust in length due to tension and thermal expansion. You should be setting you timing TDC so should still not mater...
Hatch Nation #42
Old 02-10-2013, 10:53 PM   #6
sdaddy
sdaddy's Avatar
Fan#: 105173
Yes, setting timing TDC with cams held with flat tool at the back end. Comes out at 5 degrees ( at the cams) off. Just wanted confirm.
sdaddy is offline
Old 02-11-2013, 12:26 AM   #7
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
how did you know you were 5 degrees off?
FF MODERATOR
RIFF CREW
Old 02-11-2013, 04:29 AM   #8
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
The discussion is a moot point, he probably read the degrees difference on the sprocket markings, irrelevant since the reason for the adjustable sprockets to begin with. You correct with them back to right, or what you want. There is no way to 'confirm' since every engine will be slightly different. The term '5 degrees' also useless unless knowing retard or advance and which one of two cams.
The TDC mark can be useless too since may not be true TDC which needs to be indicated out with a degree wheel. Simply bumping a stop point pin is close but all engines vary there too.
amc49 is offline
Old 02-11-2013, 10:52 AM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,816, Level 100
Points: 51,816, Level: 100 Points: 51,816, Level: 100 Points: 51,816, Level: 100
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Correct , the best thing to do is get them close with the tools for TDC then use a compression gauge to dial them in closer till you can get to a dyno
Do a compression test , then move one gear 1 mark , if compression goes up go another mark till compression stops going up by moving the gear , if you go Adv. say and get no gain in compression then go the other way , when done with that gear go to the other and do the same thing , this will get you CLOSE but you need to adjust the gears on a dyno or you may leave some power behind
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-11-2013, 09:35 PM   #10
sdaddy
sdaddy's Avatar
Fan#: 105173
Yes, you're right. I did mean the degree difference on the sprocket markings when the cam's are aligned via the tool. I checked TDC by using a the measuring end of a caliper on #1 piston and it corresponds to hitting the stop point pin. The adjustable sprocket markings are actually both 6 degrees retarded. I'll start with that and follow Tom's compression advice for the initial tuning.
sdaddy is offline
