Replacing power steering pump in ZX3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-10-2013, 01:14 PM   #1
ferrisworld
Fan#: 21716
What I Drive: 2003 Pitch Black ZX3, 1979 Light Yellow Cadillac Sedan Deville
FF Reputation: 1 ferrisworld Good Standing Member
I'm putting a new power steering pump in my 2003 ZX3 with the 2.0 Zetec. The old one worked, but was leaking from the bottom.
On further reading though, I'm worrying that I may also need to replace the high pressure line, as people claim that the internal seal is often damaged upon removal from the old pump.
I was also reading that I need a special tool to install the teflon O ring.
I don't really want to put everything back together, only to have to drain it again to do the line next weekend, so I thought I would see what you guys think.
ferrisworld is offline
Old 02-10-2013, 02:46 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
If all you are trying to fix is a leaky bottom seal on a working pump, then you probably only need this part:
http://focus.c-f-m.com/fordpowerstee...ssvt02-04.aspx
It has the white outer teflon seal and a black inner seal (which you can just make out in the pic). It's held in place by a small wire C-clip in the nut that fits into a machined groove in the ps pipe end, iirc. It's that c-clip you may destroy when you pull things apart. Since the ps line works under very high pressures, I wouldn't want to mess with anything but new parts there.
No special tools required as I recall.
Make sure it's not leaking from the pressure sensor on the side of the pump too; it's a common leak point. (It's where the wire connects to the side of the pump.)
BC_ZX3 is offline
Old 02-10-2013, 03:09 PM   #3
ferrisworld
Fan#: 21716
Hmmm, well I already got the new pump and I've got 138k miles on it. Figured it can't hurt right?
My pump doesn't have the sensor on the pump, it's on the line. I remember reading that SVTs had it on the line, and regular zetecs had it on the pump, but mine is on the line. I know it's not an SVT zetec though.
When I read about the tool for the teflon ring, it said it was to install a new ring on the nut, whereas the link has a nut with a new ring already installed.
I guess I'll see what I can do, and if the C-clip looks good, I'll just use what I have.
Old 02-10-2013, 06:52 PM   #4
ferrisworld
Fan#: 21716
Well, I couldn't tell where the c-clip was, but everything is back together and seems to be working fine. Did a test drive and I don't see any leaks after it.
