Changed alternator, radio stopped working, checked fuses, Help? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-10-2013, 12:43 PM   #1
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
Pretty much what the title says. I changed my alternator yesterday on my 2000 Ford Focus ZTS and I tried to turn on my radio and it didnt turn on at all. Completely non responsive. I hear like a little buzzing noise on the inside of my aftermarket stereo but nothing else. I even tried plugging the original stereo in and just the red flashing light on the front was flashing. Wouldnt turn on. I checked fuses and they are good.
cylenotkyle is offline
Old 02-10-2013, 01:21 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Do you have a voltage tester?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-10-2013, 01:31 PM   #3
cylenotkyle
Fan#: 107493
yes. I checked the slot the fuse goes into.
Old 02-10-2013, 01:59 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
That's great, but did you check the voltage at your wiring connections behind the radio? Other than the fuse, there should be no other disconnect from the wiring. You can look for things you might've screwed up under the hood- like the radio noise suppressor. If you disconnected that, then you will have low voltage or no voltage going from hot to the ground in your connector behind the radio. When you check hot to a chassis grounding point, you'll have voltage.
I'm not positively sure where the radio noise suppressor is on the Zetec. On the Duratec, it runs across the top of the engine, then grounds to the strut tower on the passenger side. On the Zetec, it should come out of the coil wiring harness, go to a black box somewhere, then to a ground from that box. Remove your negative terminal before you start messing with it. If the ground is disconnected, then the black wire coming out of that box will be hot, and if it is disconnected before the black box- a dead short will cause a blown fuse. There's no sense in blowing a fuse you don't expect. On the Dtec, it's the ECU fuse- so the car doesn't run if you blow it.
That's about the only thing I can think of that will cause your issues- a lost ground, or a lost noise suppressor.
Be eclectic.
Old 02-10-2013, 06:31 PM   #5
cylenotkyle
Fan#: 107493
I couldnt find the noise suppressor. And I re looked at everything I did yesterday. Still no luck. No wires are and nothing seems out of place. I even pulled the stereo out and re crimped all the wires just in case.
Old 02-10-2013, 06:40 PM   #6
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Hopefully someone else can help you out. I know how the suppressor works, but not it's location in the car with that engine.
Good luck. You should probably try to get ahold of a tester. That will help you determine if your ground at the radio is good, and if the hot there is good.
Be eclectic.
Old 02-10-2013, 06:45 PM   #7
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
radio harness was changed?
So when did you do something with your radio harness and what did you do?
mikeeshaq is offline
Old 02-14-2013, 04:17 PM   #8
cylenotkyle
Fan#: 107493
I didn't do anything around the radio or the harness. I just changed the alternator and when I was finished I turn on my car and my radio wouldn't start. I checked the fuses and slots they go in. I even checked the whirring harness (after it wouldn't turn on) and made sure all the wires were good. I even put back in the stock radio and it wouldn't turn on. I don't have any Amps or anything additional hooked up. Please help. Lol.
