ford focus mk1 disc conversion from drums - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-10-2013, 05:28 AM   #1
jason3249
Fan#: 109729
What I Drive: ford focus
FF Reputation: 1 jason3249 Good Standing Member
Hi all I'm new to this forum I'm Jay and I live in worthing... ;)
Iv got a Ford focus mk1 it's on a 01 plate but it's running drums..
Iv found this http://www.ebay.co.uk/itm/1609707824...84.m1497.l2649
He's saying it's all there to convert from drums to discs..
But just abit worried on the brake lines will I have to change them or does the brake hoses from the kit fit on my brake lines...
Iv been looking all over the net but cant find any thing to do with the brake lines do them brake hoses just fit on to my brake lines or do i need to get new brake lines from a rear disk car hope not :-) ..
Thanks all...
jason3249 is offline
Old 02-10-2013, 06:10 AM   #2
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
Points 5,927, Level 49
Points: 5,927, Level: 49 Points: 5,927, Level: 49 Points: 5,927, Level: 49
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Brake lines are fine, you'll only need to change the hoses
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 02-10-2013, 06:12 AM   #3
jason3249
Fan#: 109729
Thanks m8 but i dont have brake hoses iv just got a metal brake line going in to my drum do the brake hoses from the kit just bolt to my brake lines thanks agen...:-)
Old 02-10-2013, 06:13 AM   #4
wickedgreyzx3
Fan#: 34204
You'll remove that Piece of hard line, the original hose and the new hose will go directly to the caliper
Old 02-10-2013, 06:23 AM   #5
jason3249
Fan#: 109729
So it goes to the caliper but where does the other end go
I remove the hard metal line what all of it or does it come out in peices or does a peice undo from the back then i can fit the new hoses from the kit to where iv took the metal peice out..
So i will be left with 3 quarters of a brake line till i fit the new hoses.
I mite Sound dum but cant work it out i just dont get where the brake hose from the kit goes i no one end goes in to the caliper but what about the other end..
Old 02-10-2013, 07:07 AM   #6
Capt. Obvious!
Fan#: 108055
What I Drive: 04 ZX3 S/C, 87 VW cabby, 98 Opel
FF Reputation: 1 Capt. Obvious! Good Standing Member
Mine has had this conversion done to it. On mine it looks like the rubber hose runs from the caliper the toward the front of the car where it mates to what looks like it is the original metal brake line. It is right where the metal line goes under the sub frame and goes through a metal tab on the frame (looks to be a stock tab). There is a threaded fitting there that the rubber line is connected to (This again looks stock).
Just looked again, it's almost certainly a stock fitting, either that or the guy that did it did a kick ass job and spent way to much time making it look stock. If you look in the gap between the leading edge of the tire and the fender well clear at the bottom near the rocker panel, you should be able to see it on the sub-frame rail, just above the swing arm thing for the rear axle. If I get time later and you still cant find it I'll take a picture.
Capt. Obvious! is offline
Old 02-10-2013, 07:30 AM   #7
jason3249
Fan#: 109729
Hi m8 thanks for that cant find it and the hoses in the pic ant that long so god knows how they can reach to the front of the car hes sed on the ad and emailed me saying you want need any thing else but cant work out where the hoses go in the pic do they go on my lines or do i need to buy more stuff like new brake lines etc i thought the hoses in the pic just bolt to the lines what go in to the drum or does that peice what goes to the drum unbolt some where then i can bolt the hoses from the ebay ad/pic on to it then the other side to the caliper ;-)
Old 02-10-2013, 09:20 AM   #8
Capt. Obvious!
Fan#: 108055
They should just connect to your current brake lines. The fitting they connect to on mine isn't at the front of the car, it is just barely in front of the rear tire.
The hoses in the pic look to be the same length as the hoses on mine. The hand brake cables look the same too.
Old 02-10-2013, 09:48 AM   #9
jason3249
Fan#: 109729
Thanks m8 hope thats all i need and it all just bolts to my motor as iv just brought it it's going on a estate he sed it will fit that to so let's hope lol
Old 02-10-2013, 10:13 AM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Moved to Wheels, Tires, Brakes, and Suspension. General Technical Chat is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls.
Thanks for posting!
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
