MPG Mods - - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-11-2013, 07:28 PM   #11
roderunner
Fan#: 108779
What I Drive: 2014 White Plat. Fusion 1.6L stick
Points 113, Level 2
Points: 113, Level: 2 Points: 113, Level: 2 Points: 113, Level: 2
Level Up 26% Completed
FF Reputation: 1 roderunner Good Standing Member
Originally Posted by RonMaiden View Post
Overinflating the tires will improve MPGss but wearing them out quicker will cost you more and with a smaller contect patch you also have less grip in corners. Don't overinflate.
Yes and no. Manufacturers often set tire pressure lower than optimal to improve ride comfort, since tires are also an integral part of the suspension system. A good way to actually check for overinflation after setting your desired pressure is to chalk a line across your tires and roll your vehicle one or two revolutions in a flat parking lot. The chalk will leave a (witness) mark on the asphalt -- if a tire is overinflated, the line will not span the full width of the tread. In that case, drop your pressure and try again until the mark looks good. By using this technique you can see how far the tire pressure can be raised without overinflating.
It's also interesting to note that pressure can fluctuate more than one might imagine. My Jeep has a direct readout TPMS system so it is possible to monitor pressure continuously in each tire. Driving from San Diego to Phoenix for example, it can vary up to 7 PSI gain due to
1. internal friction (1 to 3 psi)
2. air/pavement temperature increases (up to 4 psi)
3. solar contact (1 or 2 psi)
So "cold inflation" specs would ideally be set before driving and not in the sun. If it is necessary to air the tires at the gas station for instance, you should add 2 or 3 psi to your target pressure -- you can bleed any excess off later after the tires have cooled off.
I typically set about 38 PSI cold. This should help the mileage fractionally without overinflation while insuring the pressure doesn't rise above 45 MAX after potential gains, yet going no lower than recommended after a month of natural bleed off or cold spell.
roderunner is offline
Old 02-11-2013, 07:37 PM   #12
IngotMK3
IngotMK3's Avatar
Fan#: 42911
What I Drive: MK3 Focus
Points 4,170, Level 41
Points: 4,170, Level: 41 Points: 4,170, Level: 41 Points: 4,170, Level: 41
Level Up 10% Completed
FF Reputation: 1 IngotMK3 Good Standing Member
The MK3 Focus dont have TPMS correct?
Looking at getting lightweight wheels and LLR tires for summer/when the all season wear out on my stock 16in wheels.
IngotMK3 is offline
Old 02-11-2013, 07:57 PM   #13
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,243, Level 67
Points: 10,243, Level: 67 Points: 10,243, Level: 67 Points: 10,243, Level: 67
Level Up 49% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 26 suss6052 Great Standing Member
They have TPMS as required by law for new cars afaik.
In the United States, the United States Department Of Transportation (NHTSA) released the FMVSS No. 138, which requires an installation of a Tire Pressure Monitoring System to all new passenger cars, multipurpose passenger vehicles, trucks, and buses that have a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 lbs.) or less, except those vehicles with dual wheels on an axle, as of 2007.
suss6052 is offline
Old 02-11-2013, 09:22 PM   #14
roderunner
Fan#: 108779
Points 113, Level 2
All systems activate an alarm if the pressure drops too low (usually about 25% below recommended pressure). I believe most (if not all) have a high pressure alarm also. Some vehicles can display the actual pressure but the Focus apparently doesn't offer that option.
Old 02-11-2013, 09:39 PM   #15
IngotMK3
IngotMK3's Avatar
Fan#: 42911
Can you scan or turn them off?
IngotMK3 is offline
Old 02-11-2013, 09:42 PM   #16
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 33%
No, the system cannot be disabled even via the factory IDS scan tool. You can run the car without them but it will send out an annoying warning message and a chime upon start up and the TPMS light will be on all the time. You can get a set of sensors off of ebay for less than the retail asking price usually, but you have to make sure its the correct valve stem mounted sensors in the right frequency range. Tire rack says 315 mhz should work.
suss6052 is offline
Old 02-11-2013, 09:54 PM   #17
IngotMK3
IngotMK3's Avatar
Fan#: 42911
Darn, thanks for the info dude - I will just get sensors with the new wheels from tire rack when the time comes..
IngotMK3 is offline
Old 02-11-2013, 10:25 PM   #18
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: Slammed S-10
Points 8,062, Level 60
Points: 8,062, Level: 60 Points: 8,062, Level: 60 Points: 8,062, Level: 60
Level Up 56% Completed
FF Reputation: 7 Chaos09 Good Standing Member
You can also do a front skid plate and rear diffuser to help the air flow. I picked up an average of 7mpg with mine.
Sonic's MK3 Crew #9 Chaos!
Chaos09 is offline
Old 02-11-2013, 10:27 PM   #19
IngotMK3
IngotMK3's Avatar
Fan#: 42911
Links or more info on that?
I know thats a package with the fiesta when I was looking into that model..
IngotMK3 is offline
Old 02-11-2013, 10:34 PM   #20
Creative
Creative's Avatar
Fan#: 108024
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Achieved with steeda cool air intake and short throw shifter and I dive like a grandma and run wawa 92 octane
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
