Car battery changed, now it revs right up when the clutch is pressed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-09-2013, 12:56 PM   #1
mdkmd5
Fan#: 105882
What I Drive: 2001
FF Reputation: 1 mdkmd5 Good Standing Member
Hey,
Over christmas my car battery decided to give out and the local garage replaced it. The second I got the car back it's developed a nasty revving problem when depressing the clutch whilst moving, and the car pulls away from you when you're in 2/3rd gear. It wasn't perfect before, but it certainly wasn't revving up so I'm assuming this has something to do with an ECU reset with the battery being replaced.
When the car is stationary and the engine is idleing everything is perfect. When you're moving though and you change gears the car will rev up to over 2k revs on its own, and when coming to stop it will rev right up until you have completely stopped. Garage has had a look at idle control value and throttle position sensor but he said he's really struggling with it now. It's nothing to do with the pedal because I've tried putting my foot under it and pulling it back whilst it's revving.
If you drive along in neutral and let it settle at 2k revs, you can blip the throttle ever so slightly and it revs up to over 3.5k on its own, taking 5-10 seconds to come back down to 2k. I actually don't have a clue what it could be.
Car is a 2001 focus 1.8 zetec,
Any help would be appreciated, thanks
mdkmd5 is offline
Old 03-30-2013, 05:12 AM   #2
Dsilva1
Fan#: 112026
What I Drive: T reg Green 1.8i
FF Reputation: 1 Dsilva1 Good Standing Member
Im sure ive posted elsewhere to this problem and my car is suffering this one too! :( Today Im going to check the vacuum pipes to the inlet manifold and, allegedly, there are more hoses to check underneath the throttle body.Ive already checked the throttle body to ensure its clean and shutting properly and also MAF sensor too. I think this problem is also contributing to horrendous fuel consumption. Please post if you find a solution as im banging my head on the wall over this one too.
Dsilva1 is offline
Old 03-30-2013, 03:35 PM   #3
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Originally Posted by mdkmd5 View Post
When the car is stationary and the engine is idling everything is perfect. When you're moving though and you change gears the car will rev up to over 2k revs on its own, and when coming to stop it will rev right up until you have completely stopped.
This is probably a very useless post on my behalf, however, maybe it'll highlight it for someone else.
The vehicle functions fine when it's idling. The moment it is "in motion" the computer goes haywire and starts revving the engine itself (fly-by-wire can't do that though?).
Unless! It's controlling the air intake from the idle air control valve, thus by-passing the actual throttle body.
Could it be possible that your ECU (or even more unlikely: the PCM) is actually damaged?
Quickie Google search turned this up: http://www.sixthsphere.com/forum/sho...ixed!%29/page2
Or, quite possibly, the person who looked over your TPS (throttle position sensor) made a mistake, and it actually is the TPS.
I mean no offense to anybody by that statement. But, from personal experience, people care more about money than helping.
More vehicles pushed through a garage, the bigger your paycheck, the less you need to care about helping someone that very day.
Oblivion is offline
Old 03-30-2013, 03:56 PM   #4
Dsilva1
Fan#: 112026
Have to admit Im tempted into replacing the TPS as it is not much money. Have read other threads that suggest the factory settings of the PCM are not perfect and lead to revving between gear change but the information, in my opinion, does not relate to my/our problem. Just out of interest, MDK, are you using a lot of fuel too? i would agree with our American compadre, garages are not to be trusted!! Have dealt with some blokes with diagnostic tools in the past, and they struggle to understand how the hardware works, let alone fixing my bloody car!
Dsilva1 is offline
Old 03-30-2013, 04:34 PM   #5
Oblivion
Fan#: 92148
A quickie 5 second Google search turned this up (very interesting; Read ALL the posts top to bottom):
- http://www.honestjohn.co.uk/forum/po...ex.htm?t=61198
Three people claim that replacing the TPS cured the issue instantly.
These people also describe "warm" and "cold" climates affecting it though.
In a completely unrelated, non-DTC based idea: Could it be that the clutch is slipping (doubt it)?
EDIT
Oh, and if you have a handy-dandy 8mm socket, a ratchet, and maybe a 1/4th extension: You can take that sucker (IAC or "idle air control" valve) off, and look at it yourself!
Heck! While you're looking at it, you could even use some carb & choke cleaner and clean it out for ~$5 USD.
YouTube Video
Oblivion is offline
Old 04-01-2013, 04:50 AM   #6
Dsilva1
Fan#: 112026
Thanks, Oblivion. Thats gonna be on my "to do" list tomorrow. Have ordered a manual so might fare better, navigating my way around the engine bay! I think this one is going to be a process of elimination. Im sure cleaning the IAC will help. :)
Dsilva1 is offline
Old 04-04-2013, 12:18 PM   #7
Oblivion
Fan#: 92148
You're welcome, Dsilva1. :)
Have you cleaned the IAC out yet? What's the status update? It's been 4 days!!
Oblivion is offline
Old 04-05-2013, 06:58 AM   #8
Dsilva1
Fan#: 112026
Hi oblivion. IAC cleaned. Still no joy. The throttle body is coming off today as I feel this might not be shutting properly. Will keep you posted. :)
Dsilva1 is offline
