For Sale: Built Engine - Built for 350-375whp Goal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-09-2013, 08:56 AM   #1
AcIdBuRn02ZTS
Fan#: 42027
What I Drive: 2002 Twilight Blue ZTS Sedan
FF Reputation: 5 AcIdBuRn02ZTS Good Standing Member
Desc: Built Engine - 350-375whp Goal - Built for boost
Contact: AcIdBuRn02ZTS@yahoo.com, PM
-Built Engine-
Asking Price: PRICE DROPPED - $1900
Includes: (All items with ** came from Steve @ Tousley Ford)
Zetec Block/Crank (block had less then 200 miles on it when I got it... stock bore... cleaned and honed)
SVT Rods/Pistons (20k miles on the rods and pistons but very clean)
**SVT Ring Set (upper comp. rings gapped to .017")
Clevite 77 Rod & Main Bearings
ARP Main Studs (All ARP Fasteners where torqued to spec using ARP Moly Lube)
ARP Rod Bolts
ARP Head Studs
Ported and Polished Stock Head (Valves lapped, new valve seals)
**Zetec Head Gasket
Comp Cams Stg. 2 Cams
UR Adjustable Cam Gears
Massive Cam Gear Hardware
Ported Early 2k Intake Manifold
Later Style FC 65mm Throttle Body
Aluminum Valve Cover
**Every Seal, Gasket, etc..
**Oil Pump
**Water Pump
**Timing Set
**All Engine Sensors (including MAF)
Will also include the complete set of Billet/Poly motor mounts.
I'm sure there are a few other things I'm forgetting... but anyways... engine was broke in NA form. Oil changed after first 30 minute run, then at 50 miles, then at 100 miles, then again at 500 miles. Changed to Mobil1 5w30 at 3k miles. Engine has ~8k miles on it at this point. Turbo system listed above was installed around the 5k mile mark. Rev. limit was set at 7200 rpm. Engine runs GREAT... no leaks, no issues what so ever. I built the engine with a 350-375whp goal in mind. It was never ran lean or with unsafe EGTs. Depending on what you are doing, you might need another oil pan because the oil pan coming with the engine has a bung currently welded in it for the turbo oil return. This engine was built for boost and built to be reliable in a daily driven application. No corners where cut... all parts are brand name or came directly from Steve @ Tousley Ford.
Here are a few pictures from when I built it...
I prefer the engine be picked up in person due to freight costs. I am willing to ship via freight at buyer's expense. A deposit is required before the engine will be pulled from the car.
-Chris
2002 - Twilight Blue ZTS Sedan
Built Motor, Getrag w/ Quaife, Eibach Suspension, GT3071R Turbo.. Destroying Tires thru 3rd @ 10psi = Priceless. 20+psi soon to come.
1987 MKIII Supra Targa
AcIdBuRn02ZTS is offline
    Quick reply to this message
Old 02-10-2013, 09:17 AM   #2
AcIdBuRn02ZTS
Fan#: 42027
Morning bump... perfect engine for those looking to push their supercharger setup or for those planning on a mid level turbo setup
-Chris
Old 02-10-2013, 09:29 PM   #3
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
What I Drive: 2000 Malibu Blue ZX3
FF Reputation: 2 cody.carr Good Standing Member
Buy-Sell-Trade Rating: (6)
I want this so bad. It's everything that I need...
2000 ZX3: ╠╬╝ Iceman CAI, Raceland Coilovers, SVT Header Swap
HOTM February '13 HN #06 RR #39
cody.carr is offline
Old 02-10-2013, 10:08 PM   #4
AcIdBuRn02ZTS
Fan#: 42027
Well... lets deal :)
pm sent
-Chris
Old 02-11-2013, 07:54 PM   #5
AcIdBuRn02ZTS
Fan#: 42027
bump
Old 02-11-2013, 08:56 PM   #6
J0EC00L
J0EC00L's Avatar
Fan#: 86480
What I Drive: 2001 Ford Focus
Points 4,719, Level 43
Points: 4,719, Level: 43 Points: 4,719, Level: 43 Points: 4,719, Level: 43
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 1 J0EC00L Good Standing Member
Why are you selling it?????
Do you have all the receipts for the engine?
Would you guarantee that the engine is in perfect shape? Sign an agreement if I was to purchase it.
I am very interested.
J0EC00L is offline
Old 02-11-2013, 08:58 PM   #7
AcIdBuRn02ZTS
Fan#: 42027
PM Sent...
Selling because I'm parting out the car... want to get some bills paid off.
As far as receipts go... I'm sure I can come up with some of them... its been a while since I built it... and I did all the work.. so it would just be for parts.
And no I will not put my name on a piece of paper that could possibly bite me in the rear.. If whom ever buys it blows it up, then says it was junk when they got it.. that could put me in a bad spot. Sorry but no. The car is still fully assembled... if you want to be sure... come up and take a ride. I've got compression and leakdown testers here that you can use if you feel the need.
Thanks
-Chris
Old 02-12-2013, 07:09 PM   #8
AcIdBuRn02ZTS
Fan#: 42027
bump
Old 02-13-2013, 07:13 PM   #9
AcIdBuRn02ZTS
Fan#: 42027
-sale pending-
Old 02-15-2013, 08:55 PM   #10
XPM5G
XPM5G's Avatar
Fan#: 96330
What I Drive: '78 Chevy Custom Deluxe
Points 292, Level 5
Points: 292, Level: 5 Points: 292, Level: 5 Points: 292, Level: 5
Level Up 84% Completed
FF Reputation: 1 XPM5G Good Standing Member
Know sale is pending but is displacement different from stock?
XPM5G is offline
