motor SVT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-08-2013, 04:08 PM   #1
whimsicalpouch2
Fan#: 87978
What I Drive: 2002, black SVT focus
Points 4,736, Level 43
Points: 4,736, Level: 43 Points: 4,736, Level: 43 Points: 4,736, Level: 43
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 4 whimsicalpouch2 Good Standing Member
Buy-Sell-Trade Rating: (6)
motor SVT
how easy is it to change the bushings in my passenger mount and upper trans mount to poly mounts?
mine need to be changed, i recently changed my dogbone, and i feel like that'll wear out faster with the other 2 mounts being bad aswell seeing that they are stock with 171000.
i would rather change the bushings out but if its cheaper than buying the whole mount, id rather do that
Most Excellence!
#586 of #4788
whimsicalpouch2 is offline
Old 02-08-2013, 05:25 PM   #2
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,819, Level 59
Points: 7,819, Level: 59 Points: 7,819, Level: 59 Points: 7,819, Level: 59
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 13%
FF Reputation: 9 ViperThreat Good Standing Member
Getting them in and out isnt very difficult, just put a jack under your engine to hold it up while you work on them
Pressing the new bushings in however is a bit difficult. you may need some sort of press to do it.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 02-10-2013, 01:51 PM   #3
whimsicalpouch2
Fan#: 87978
where can i get the new bushings for the 2 mounts?
Most Excellence!
#586 of #4788
Old 02-10-2013, 01:53 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
From our vendor Central Florida Motorsports.
They warn you that poly mounts will cause vibration and are race only, however, I have poly mounts on my engine and I don't think the vibrations are all that bad. Yes, it does vibrate at idle, but as long as you do the mount installation correctly- it's not horrible. As soon as you give the car some gas- no more vibration. Acceleration is more immediate.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-10-2013, 03:53 PM   #5
whimsicalpouch2
Fan#: 87978
would a jack under the transmission be able to hold the engine in place while i would do the upper trans mount then followed by the passenger mount?
Most Excellence!
#586 of #4788
Old 02-10-2013, 03:53 PM   #6
whimsicalpouch2
Fan#: 87978
i'm not worried about vibrations, i like the stiff ride my car already has and the vibrations won't affect me
Most Excellence!
#586 of #4788
Old 02-10-2013, 04:18 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Jack under the trans for the trans mount, and under the oil pan for the front engine (passenger side) mount. Just make sure that you are not putting your mount bolt in a bind when tightening. You will damage things if you pull the motor up to the mount with the bolt(s).
Be eclectic.
Old 02-10-2013, 05:21 PM   #8
whimsicalpouch2
Fan#: 87978
isn't it bad to lift the engine by putting a jack on the oil pan? wouldn't that crush it and make me get a new oil pan??
Most Excellence!
#586 of #4788
Old 02-10-2013, 05:56 PM   #9
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
You use a block of wood to span the oil pan so the weight is distributed on the sides. That's given in every manual. I prefer plywood myself, but if your jack's saddle is big enough then you can use a 2x4. You should do the same thing for the transmission- it is not wise to jack up on cast aluminum without having wood in there to absorb the hardness of the saddle.
Be eclectic.
Old 02-13-2013, 03:52 PM   #10
whimsicalpouch2
Fan#: 87978
alright alright sounds good thanks. i don't have to jack up the engine/trans too much right? just enough so its supported? and its only like what 2 bolts for the passenger and then 4? for the upper trans?
Most Excellence!
#586 of #4788
