Exploding manifold help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-08-2013, 12:53 AM   #1
Nyberg
Fan#: 107742
What I Drive: 2002 sonic blue SVT ZX3
FF Reputation: 1 Nyberg Good Standing Member
Unhappy Exploding manifold help
Bent valves, head redone car ran great. Boy flooded car plugged in block heater, tried to start car and the intake blew in half. Long story short car is back together and it just will not run properly. I have eliminated timing, vacuum leaks, tps, coil, iab valve as the culprits. I cleaned the MAF, I have the exhaust below the header off and it still runs terrible, which makes me think the cat is not plugged. Car is running rich, new plugs look moist, fuel pump kicks in. Would the 02 sensors not make a difference till the car warms up? I am pretty sure they do not make any adjustments till the sensors are warmed up Just do not know what could be causing the problem? No wiring issues that I can see, other than the pigtail to the coil looks ratty but i tested the plug to further down line and it seems to be fine. Off to find a code reader tomorrow and see what comes of that, any suggestions would be great.
The car will not hold idle and wants to die unless you give it gas. Even when you give it some gas it runs lousy.
Cheers
Gerry
Nyberg is offline
Old 02-08-2013, 10:33 AM   #2
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,119, Level 34
Points: 3,119, Level: 34 Points: 3,119, Level: 34 Points: 3,119, Level: 34
Level Up 46% Completed
FF Reputation: 2 Slo86GT Good Standing Member
Cam timing? Had a Nissan SR20 that was 2 teeth off and wouldn't run without the throttle half open, and ran even better (lol) when the air compressor was blowing directly into the throttle body. Don't ask me, I dunno why the hell we tested that.
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 02-08-2013, 10:52 AM   #3
Nyberg
Fan#: 107742
Timing is bang on and VCT is set, new plugs as well.
Nyberg is offline
Old 02-09-2013, 04:33 PM   #4
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
could some of the manifold shrapnel gotten blown/sucked into the intake ports?
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-09-2013, 04:58 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,775, Level 98
Points: 27,775, Level: 98 Points: 27,775, Level: 98 Points: 27,775, Level: 98
Forum Activity 4%
It's most likely that one of the rubber tubes was damaged. You should remove those and inspect them. One might even be loose, those can be a pain. The symptoms you're giving are typical of massive vacuum leaks.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 02-09-2013, 05:09 PM   #6
Nyberg
Fan#: 107742
I am ordering an intake in the meantime I pieced my old one together and thought i had it sealed up. Finally decided to yard it out and you are right there is a small leak along one of my joints. Just did not want to believe I missed it. Anyways looks like mystery solved and I will let you know how it goes
Cheers
Gery
Nyberg is offline
Old 02-09-2013, 07:58 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
On the intake itself or one of the flexible connectors? CFM makes polyurethane replacements for those rubber parts that you might want if that's where the problem is.
Be eclectic.
Old 02-09-2013, 08:30 PM   #8
Nyberg
Fan#: 107742
Intake, as it blew completely in half, hard enough to knock the shift cable out of its holder. I think my son filled his pants when it went off.
Nyberg is offline
Old 02-09-2013, 08:49 PM   #9
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
LOL well they will learn eventually- right? Now you can teach him the importance of knowing the emergency start method in case he floods another EFI engine or needs to turn over an engine without using fuel.
Be eclectic.
Old 02-10-2013, 01:41 PM   #10
Nyberg
Fan#: 107742
All cleared up fiberglass and the right stuff gasket sealer and we are good to go.
Nyberg is offline
