Go Back   Focus Fanatics > Model Specific Discussions > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 02-07-2013, 07:51 PM   #1
Rod in NC
Fan#: 108982
What I Drive: 2004 Blue/Blue SVTF
FF Reputation: 1 Rod in NC Good Standing Member
HID headlamp identification needed
Ok, just bought my second SVTF (2004 sonic blue). The previous owner had retrofitted it with HID headlamps, but I have a question on their functionality. Everything seems to function fine...hi/low on the projector, turn signal on the amber lens, tiny 1" parking light. My question is this. There is another lens/bulb inboard of the hi/lo projector lens. It does nothing. I have not dug into the wiring yet, although I can see down behind the headlight housing where he tapped into the harness. I've read through some of the forums...is this a Canadian-only driving light, or is is supposed to function in parallel with low beam? Just seems odd that there is this lense with a bulb in it that doesn't do anything. I thought I would seek advise on normal function here before I pulled out the headlamp assy to see what the wiring looks like. On the lens is 'DEPO 330-1124' but I haven't found much via google. thanks for any help. If I can figure out how to upload a pic I will. -Rod in NC
2004 SVTF Red/Red stock 95k
2004 SVTF Blue/Blue K&N drop in filter, Borla exhaust, 155K
Rod in NC is offline
Old 02-07-2013, 07:58 PM   #2
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
FF Reputation: 20 xxMichaelAnthony Great Standing Member
330-1124 are the Depo Machs
http://www.depo.com.tw/asp/pdf/U_FD_...CUS_FUSION.pdf
IIRC on the real Machs, the inside lamp is supposed to only come on for flash to pass.
http://effyeahsmallfords.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 02-07-2013, 11:14 PM   #3
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
What I Drive: 01 Blue SE / 09 Black Coupe SE
FF Reputation: 28 Rabbitccc Great Standing Member
Buy-Sell-Trade Rating: (31)
If they look like these just chrome. They are DEPO versions of the SVT Mach HIDs. On the SVT Mach HIDs the inner bulb your probably questioning is the high beams. The center actual projector is the actual Low beam HID. It sounds like this guy put in his own bi-xenon projector that does both low and high. For whatever reason.
o/_____\o
(8Oo)FORD(oO8)---SEDAN REVOLUTION
U_{=SR114=}_U----Upgrades In Profile
Rabbitccc is offline
Old 02-07-2013, 11:24 PM   #4
swansong
swansong's Avatar
Fan#: 83576
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 4 swansong Good Standing Member
The Mach HID is bi-xenon. When the "brights" are selected the mechanical cutoff shield is physically moved out of the way, allowing a full circle of illumination. At the same time, the high beam halogen lights, the inboard ones, should also come on. There is something wrong with the wiring if they don't. That said, the halogen really don't so very much in addition to the high-beam HID.
Use this link to figure out what's going on with the wiring:
http://www.ofoc.ca/hid/index.html
Mine: 2002 Focus SVT: 137k, Sonic Blue, #1654, Moonroof, Winter Pack, Audiophile
Mods: Tom's Tune, Borla, CFM STS, painted Machs, Euro grille
Hers: 2010 Focus SES: 60k, Ebony, Auto, Moon and Tune
Mods: Stock!
swansong is online now
Old 02-08-2013, 06:36 AM   #5
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT
FF Reputation: 46 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (8)
^^ This
Here's how mine work.
Low beam with middle HID's only:
High beam with both lights on:
The center halogen don't add much light by themselves but I find they do add a yellower ting to the light output versus the white/blue of the HID's. This helps you to see the edge of the road better when there are no lines and makes it easier to see small details as you approach them.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
02fordsvt is offline
Old 02-08-2013, 06:02 PM   #6
Rod in NC
Fan#: 108982
Perfect! Thanks for the info and pics, guys. I like the idea of having the halogen kick on for high beams only. Yes, my DEPO lights are the chrome style. Knowing that now should help me find some pin-out diagrams of the wires and connect. Looking forward to pulling off the headlight and digging into the wiring to decode how to get that bulb to kick on. Thanks again. -Rod
Old 02-09-2013, 02:01 AM   #7
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Here's the diagrams I used for my car.
http://forums.focaljet.com/mk-i-exte...-pictures.html
And this:
http://ofoc.ca/hid/step05.html
Old 02-09-2013, 08:48 AM   #8
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
Well dang. Sorry about my incorrect post. The whole time I've been running my Machs in my old car and I had it wired wrong. I knew they were supposed to be bi-xenon, but I thought they just didn't use them. Here this whole time it was my Jerry rigged wiring job. Good to know.
o/_____\o
Old 02-09-2013, 01:16 PM   #9
Rod in NC
Fan#: 108982
Rabitccc, seeing your post, I'm now wondering if my headlights themselves are functioning properly. This morning I pulled out the DEPO headlight. I pulled back a bunch of loom off the headlight and main harness...I see no splicing. The plug going into the back of the headlight looks like oem Ford (had 'FED' on the side of the plug) and not a VW plug with yellow wires. So my bi-xenon work, my turn signals work and my little parking light works. Just not my halogen. I think I will leave as is and not mess with it unless any other ideas. I don't feel like tearing into the back of the headlight assy, but this still has my curiosity. I just ordered a factory service manual and wiring diagrams off Ebay...when those show up I will confirm the wires in the stock connector. -Rod
Old 02-09-2013, 01:32 PM   #10
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
FF Reputation: 28 thenorm Great Standing Member
the Mach HID projector is bi-xenon, but it is not wired that way.
to get mine to work proper as bi-xenon i had to jump a wire.
instruction here
http://www.ofoc.ca/hid/step05.html
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
