Ford Focus Mk2 Both Headlights Stopped Working - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-07-2013, 01:19 PM   #1
simon238
Fan#: 109639
What I Drive: 2007 Ford Focus 1.8 TDCi
FF Reputation: 1 simon238 Good Standing Member
I stumbled across this forum whilst searching for the answer to this problem. In that case the guy seemed to get lucky and just had to replace both headlight bulbs.
I have replaced a bulb and checked the fuses and they are still not working.
I don't really know a lot about cars, but I am assuming the problem must lie either with the switch or the relay. Does anyone know which might be more likely? And also which is easier to replace/diagnose?
Thanks for any help
simon238 is offline
Old 02-07-2013, 04:14 PM   #2
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
I have been chasing invisible electrons for 40 years [electronic technician]
You absolutely need a multimeter or at least a 12 volt test light
On the fuses that I have seen, there is a bare spot on each end
On end of voltmeter/test light on ground. Now place probe on each bare spots , one at a time, on the fuse. What do you see?
Still confused? Go to Youtube and there are multitude of videos of varying quality out there.
Type in search alternator, battery, multimeter this ought to get you going
BTW get the cheapest multimeter
mikeeshaq is offline
Old 02-07-2013, 09:44 PM   #3
focusonthefocus19
Fan#: 104272
What I Drive: 2002 yellow focus zx3
FF Reputation: 1 focusonthefocus19 Good Standing Member
I've had this happen in my 2002 ZX3. There is a little black ground wire running up from a wire harness to the negative terminal on your battery. It's near your windshield washer fluid. Check if the little connector is corroded, and broken. Mine was really corroded, and it snapped off. As soon as I fixed it it worked just fine.
focusonthefocus19 is offline
Old 02-08-2013, 12:19 AM   #4
joser831
Fan#: 107975
What I Drive: 2000 Red zx3
FF Reputation: 1 joser831 Good Standing Member
If both head lights went out you problably hace a short to ground. Check youtube out or the wiring diagram and youll be able to figure out where the ground is once found replace the wire :)
joser831 is offline
Old 02-08-2013, 03:16 AM   #5
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
Not sure if it's the relay and you have minimal skills/knowledge? No problem. Drive to your local auto parts store. Use your owners manual to locate the relay. Turn on your headlights and ten rap the relay with the handle of a screwdriver. Did the lights come on even for a second? If they did then odds are it's the relay. If not it could still be the relay so pull the relay, purchase a replacement (< $10) and it. install it.
Problem solve? If so, Great! If not, you're out $10, Big deal
This is known as fixing a problem by throwing party's at it. It's a legit technique when the parts are cheap and limited tools/time prevents a proper diagnosis. So go ahead, throw a fuse at it, cost <$1,.
Then throw a relay at it. Still does not work, well you can try another fuse under the theory that the original relay was shorted causing both the original and replacement fuses to blow
After this your next step is a proper diagnosis. This means taking it to a pro or vac quoting the tools and skills required.
Hope this helpedi
Milton is offline
Old 02-08-2013, 06:10 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Automotive relays rarely go bad. I'd guess that the switch went bad first. Now, do your parking lights, or marker lights work when you turn the headlight switch on?
Have you checked the fuses? A fuse diagram and explanation of what each fuse does is located in your owner's manual. It's easier to look through there and find the related fuses, than it is to pull each fuse out.
You can also trace the wiring from the passenger side headlight down and around to the driver's side to see if there is any damage. You should also check the high beams to see if those come on at all.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
