steering wheel shakes/vibrates over 60mph - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-07-2013, 06:47 PM   #21
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Have a friend follow when you go down the road- see if the rims, run true or wobble
Cheap diagnostic- just owe friend a favor
mikeeshaq is offline
Old 02-08-2013, 08:31 PM   #22
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,380, Level 20
Points: 1,380, Level: 20 Points: 1,380, Level: 20 Points: 1,380, Level: 20
Level Up 80% Completed
FF Reputation: 1 coldbear Good Standing Member
Bent rims
I've bent two on my 02 since I bought it. I swear these Aluminum wheels made in China have to be junk. The least pot hole one hits causes a flat spot on the wheel. And as far as balancing? They can balance a cement block but making it go down the road smooth?? Now you know what I mean. Cost to have my wheels reconditioned? $100.00 apiece. Ouch....damm that hurts.
coldbear is offline
Old 02-08-2013, 11:55 PM   #23
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
So what do they do when they recondition a wheel?
amc49 is offline
Old 02-09-2013, 07:04 AM   #24
coldbear
Fan#: 78292
How do they straighten em'?
They mount the bent rim on a lathe and apply torch heat on the flat area. Then rotating the rim, they take a staionary roller and apply pressure on the insise section of the condition. rim. Gradual rotations and pressures bring the wheel back to original. The outfit that performs this task act like its secrete science but it's really a 20 min. job.
coldbear is offline
Old 02-09-2013, 07:39 AM   #25
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
Points 5,927, Level 49
Points: 5,927, Level: 49 Points: 5,927, Level: 49 Points: 5,927, Level: 49
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Originally Posted by mrdeath2000 View Post
I had this issue on mine, couldnt figure it out. Once I replaced my Front lower control arms, struts, mounts and swaybar links + alignment, it was all good.
Upon inspecting the parts I removed, my guess was the swaybar links because the joints were floppy, not tight at all.
They're pretty cheap on Rockauto.com, spring for the moogs, but anything is better than nothing.
lets dump 600 dollars into a 10 year old car with limited information from the original poster. BRILLIANT
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 02-10-2013, 11:09 PM   #26
amc49
Fan#: 96610
Forum Activity 40%
Hey, the way everyone throws parts at a problem, why not?
I myself would not prefer to re-straighten an aluminum alloy wheel, too easy to be cracked. Steel, yeah, I've done it by hand with no lathe............
amc49 is offline
Old 02-11-2013, 02:15 AM   #27
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
Dardas,
Hopefully who ever sold you the new tires would not let you mount them on bent rims. If your rims are bent replace them, the cheapest way would be to find some used stock rims.
What you need to do is to go to a front end specialist that can drive over 60. Tell him you are not paying him to replace ball joints, struts or anything else. What you are paying is for him to solve the problem. Sometimes I hire a mechanic to replace a part or to perform a service. Other times I hire them to diagnose and solve an issue. Sure a professional will want a fee to diagnose and prepare a quote and that is fair. Shop around for a good front end specialist
Since your car is ten years old and you do not know how it was maintained for the first eight, it maybe that most of your front end components are/were shot. Since you do not have the knowledge to determine if a part needs replacing, find a pro that can.
Last edited by Milton; 02-11-2013 at 07:27 PM. Reason: Addressing the post to Dardas
Milton is offline
Old 02-11-2013, 05:31 AM   #28
amc49
Fan#: 96610
Forum Activity 40%
X2 and absolutely. What most techs love for you to do is come in already with the idea of what is wrong yourself, that way they do not have to diagnose and can blame you when the outcome is not right. Like free money. That's most likely how so many on this site waste so much money on changing parts, they are sure of what the problem is until the solution does not fix it, having listened way too much to Dad or brother or the 'family friend' who has no clue. The so-called family friend who is a 'trained ASE mechanic' has wasted billions of other people's dollars and pretty much gets off scot free. Of course half the time he does not even exist.........
amc49 is offline
Old 02-11-2013, 06:00 PM   #29
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
When I bought my Se there were a set of old escort steel wheels on them with shot tires (belts broken and the lot) that looked like hell.
I bought a set of 4 steel wheels off a crashed Focus for $80 and a $15 set of plastic wheelcovers from BiMart.
They look sharp, and they don't require those low-sidewall-profile tires that are so close to the wheels that every time you hit a pothole the wheel pooches in. And they clean up nice in the car wash, I don't have to sit in a puddle of dirty water for an hour with a rag, cleaning them.
I'm not going around 90 degree corners at 80Mph so the increased sidewall flex is not an issue. But I do hit a lot of crummy roads with holes in them every day.
tmittelstaedt is offline
Old 02-11-2013, 07:32 PM   #30
Milton
Fan#: 89715
Points 328, Level 6
This thread is for Dardas and his problem
tmittelstaedt, I believe this thread is for Dardas and his issue. If you are having an issue with your car and desire help, you should start your own thread.
Milton is offline
