2000 Ford Focus ZTS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2013, 02:45 PM   #1
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
2000 Ford Focus ZTS
I have a 2000 Ford Focus ZTS 2.0 4 Cylinder DOHC Engine with a Manual Transmission.
My Engine is shaking and causing my entire car"mainly the dash" to vibrate. I dont know if its the engine mounts or not. Could the mounts being improperly mounted cause this problem???
cylenotkyle is offline
Old 02-06-2013, 03:27 PM   #2
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Yes sir its those mounts
When did you last replace your mounts? How many did you replace if not all three and which ones?
Did you purchase this mounts from Ford or from somebody else?
mikeeshaq is offline
Old 02-06-2013, 03:34 PM   #3
cylenotkyle
Fan#: 107493
I've never replaced the mounts. I've only had the car for 3 months. What type of mounts should I replace them with? And how do I replace them?
Old 02-06-2013, 04:23 PM   #4
mikeeshaq
Fan#: 72526
There is controversy regarding motor mounts
Some say go to Ford for all three
Alot will say, Go to Ford for passenger side, the other two can be aftermarket
Only a few will say aftermarket is good for all three
IMHO go to Ford for all three
For the replacement procedure search for motor mounts in this forum
Maybe others will chime in
Old 02-07-2013, 03:31 AM   #5
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Go for passenger side first, then trans top if need more improvement. If you cheap out and buy Anchor brand there don't come back crying about it, you made the choice.
amc49 is offline
Old 02-07-2013, 04:30 AM   #6
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,304, Level 100
Points: 35,304, Level: 100 Points: 35,304, Level: 100 Points: 35,304, Level: 100
Level Up 0% Completed
Forum Activity 3%
I agree with this, the passenger side is known to go bad. If seen them split in two before.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is online now
Old 02-07-2013, 10:48 PM   #7
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
Check the torque mount, though. I suspect that many passenger mounts are broken by excessive flexing in the torque mount. if you get under the car and the torque mount is bad you can rock the engine back and forth with your hand and see it.
tmittelstaedt is offline
Old 02-08-2013, 07:18 PM   #8
amc49
Fan#: 96610
Forum Activity 3%
Every Focus ATX I've driven will pretty much exhibit the clunk of a loose dogbone you can easily feel by rocking power going on and off while driving, I'd think MTX would show it even more pronounced.
Easiest way I've seen to tear the bottom rubber out of pass side is to strike or jump a curb or bump something with wheel on that side to come to a sudden stop. The mount only thing holding engine from moving front to rear, it easily rips out doing that from engine inertia. Pretty goofy to engineer that mount without a front/rear restraint link built into it, the Japanese certainly don't.
amc49 is offline
