Will not start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2013, 12:35 AM   #1
Jbrooks54
Fan#: 109598
What I Drive: 2002 light green focus
FF Reputation: 1 Jbrooks54 Good Standing Member
Will not start
I drive a 2004 ford focus. Today when I started it, it shuttered until I put it in reverse. It was fine until I came to a stoplight, it then sputtered and died. When I tried to restart it, it would turnover then immediately die. I was told it could be my fuel pump, starter, or EGR valve. Anybody have any thoughts on this?
Prior to this the check engine light was not, and it will not start to see if it is on or not.
Jbrooks54 is offline
Old 02-06-2013, 12:37 AM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
If it was on, there will be a code stored. I would start by finding out which code it is and go from there. There are a lot of possibilities.
jetrinka is offline
Old 02-06-2013, 03:48 AM   #3
custer3_5
Fan#: 109457
What I Drive: 2008 jeep liberty dark blue
FF Reputation: 1 custer3_5 Good Standing Member
That's what mine did last year. I dropped a valve and screwed up the whole motor. Now I'm going to attempt an engine swap, from a sohc to a dohc zetec
custer3_5 is offline
Old 02-06-2013, 06:04 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
This sort of thing only happens to the SPI engine.
To the OP, please identify your engine for us. Go look under the hood, Ford used 2 different 2.0 engines in that YM vehicle. One will have spark plugs that go into the top of the valve cover, and Zetec on the valve cover. The other will have spark plugs that go into the side of the cylinder head, and "Split Port Injection" on the valve cover.
Dropping a valve creates a lack of compression, as does a timing belt, so if your engine is turning over faster than it used to- that is a sign of something other than a fuel pump. You should be able to hear the fuel pump buzz for approximately 3 secs after turning the key from off to on. You can hear this in any car, so go listen in a running car so you know what to listen for. If you don't hear the fuel pump buzz, that is one sign of a bad fuel pump.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-06-2013, 05:27 PM   #5
Jbrooks54
Fan#: 109598
It's a 2.3 Liter engine. I had someone listen for the buzzing sound near the gas tank when I turned the car on. No sound detected. Sounds like a bad fuel pump? :(
Old 02-06-2013, 06:59 PM   #6
custer3_5
Fan#: 109457
Some cars have a little door above the fuel pump so u can change them. I haven't seen a focus yet that has one. So that means that u will have to drop the tank. No big problem. Just unhook the bands that hold it up and down it comes. If u have any trouble just ask for the help
