Suspension rules for STF - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 02-05-2013, 09:01 AM   #1
fighing2succeed
Fan#: 81338
What I Drive: 02 Red SVTF
Points 101, Level 2
Points: 101, Level: 2 Points: 101, Level: 2 Points: 101, Level: 2
Level Up 2% Completed
FF Reputation: 1 fighing2succeed Good Standing Member
I'm considering on buying coilovers for my Focus but have a couple questions. I'm under the impression from the rule book that you can't use a spherical bearing in the rear lower eyelet and that the spring can't be moved to run the coil over the shock???
The coilovers
The bearings
The rules
14.8 SUSPENSION
A. Ride height may only be altered by suspension adjustments, the
use of spacing blocks, leaf spring shackles, torsion bar levers, or
change or modification of springs or coil spring perches. This does
not allow the use of spacers that alter suspension geometry, such as
those between the hub carrier and lower suspension arm. Springs
must be of the same type as the original (e.g., coil, leaf, torsion bar,
etc.) and except as noted herein, must use the original spring attachment
points. This permits multiple springs, as long as they use the
original mount locations. Coil spring perches originally attached to
struts or shock absorber bodies may be changed or altered and their
position may be adjustable.
Spacers are allowed above or below
the spring. Coil springs may incorporate spring rubbers. Suspension
bump stops may be altered or removed.
B. Suspension bushings may be replaced with bushings of any materials
(except metal) as long as they fit in the original location. Offset
bushings may be used. In a replacement bushing, the amount of
metal relative to the amount of non-metallic material may not be increased.
This does not authorize a change in type of bushing (e.g.,
ball and socket replacing a cylindrical bushing)
or use of a bushing
with an angled hole whose direction differs from that of the original
bushing. If the Stock bushing accommodated multi-axis motion via
compliance of the component material(s), the replacement bushing
may not be changed to accommodate such motion via a change in
bushing type, for example to a spherical bearing or similar component
involving internal moving parts
. Pins or keys may be used to
prevent the rotation of alternate bushings but may serve no other
purpose than that of retaining the bushing in the desired position.
Are these coilovers legal for stf?
fighing2succeed is offline
Old 02-06-2013, 11:10 AM   #2
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
If you go back to stock category allowances, sphereical bearings in the shock absorbers is allowed. Any changes allowed in stock are allowed in ST. Moving the spring position to be around the shock body looks like a no-go though.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 02-06-2013, 11:31 AM   #3
fighing2succeed
Fan#: 81338
Points 101, Level 2
Thanks! I just got this confirmed on the scca forums also. Looks like getting custom spring perches and new springs and I'm good. I wish someone made rear spring perches for a 2.5" springs for the focus
Old 02-06-2013, 08:15 PM   #4
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Interesting find about the springs. I didn't know that.
But then again, I haven't seen much suspension upgrades for the Focus that move the Spring over the shock in the rear.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
