EGR Insufficient Flow. Tried searching already. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-05-2013, 12:30 AM   #1
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
Car: 2003 Zetec, Automatic
Issue: p0401 code (EGR Insufficient Flow)
After a long time of plucking at this...
I've tried cleaning the valve. It's spotless. I replaced the tube, absolutely free/clear of any buildup. I checked for leaks, none whatsoever. I replaced the DPFE sensor. Could this be it? I got a BWD from Advance Auto Parts when I worked there... Could this be it? I've heard that Foci are pretty picky when it comes to sensors... As far as O2's are concerned, I use strictly NTK's. Could the DPFE be just as "choosy"?
Andrews-bad-SE is offline
Old 02-05-2013, 12:43 AM   #2
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
when mine had that code the vac line from the vac solenoid to the egr valve then to the dpfe had a hole worn in it from rubbing on something on the firewall for ten years check those little plastic vac lines carefully.
don627 is offline
Old 02-05-2013, 12:47 AM   #3
Andrews-bad-SE
Fan#: 100389
Hadn't thought of that! Lol good idea, I'll do that tomorrow. Also, I noticed you're from Dayton? I just moved to Cleveland from St. Louis. What kind of things should I be concerned with as far as vehicle inspection?
Old 02-05-2013, 01:17 AM   #4
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
The DPFE. They commonly get a small amount of water in them to corrode and fail, water vapor is present in all engine exhaust. The sensor actually only has a layer of RTV maybe .010" thick to protect the sensor strain chip, eventually the water gets through that.
I had trouble with a newer design on my '02, the '00 never has had trouble at all (firewall mounted with longer hoses). The '02 failed two sensors, the very short vacuum lines (2 inch long) had something to do with it I thought. Too easy for water to get into it, too short a path. The bad DPFEs both had water droplets in them when disassembled. I used 6 feet of vacuum line cut in two for 3 foot pieces and ran the extra line down back of motor for moisture trap, also remounted the DPFE up higher to the intake tube, now water has to go up a long distance to get to the sensor. The sensor used to freeze water in it too when temps went below freezing, the motor would cough and spit since EGR was on at cold idle, a big no-no. Since the mod several years ago no trouble at all, problem cured.
amc49 is offline
Old 02-05-2013, 01:23 AM   #5
Andrews-bad-SE
Fan#: 100389
Wow, good thinking! I remember my engine light being off for a long time after I thought I had fixed it... and now that I've been in Cleveland with the awesome cold-as-heck temperatures... it's all beginning to make sense.
Thanks a lot for the insight guys!
Old 02-05-2013, 09:49 AM   #6
don627
Fan#: 56863
Points 208, Level 4
Forum Activity 2%
we don't have vehicle inspection down here, I don't know if cleveland still has it or not. Yes if the dpfe gets water in it it will fail but, you said you replaced it. In my case my dpfe was doing its job by triggering the cel with the insufficient flow code after I replaced my vac line and unplugged my batt for a few minutes no more cel and even better no more stalling at idle in park. I love cleveland by the way.
don627 is offline
Old 02-06-2013, 03:11 AM   #7
amc49
Fan#: 96610
Forum Activity 11%
DPFE does not trigger the CEL, the PCM does once it decides the DPFE not outputting what PCM expects. A fine point but helpful in troubleshooting.
amc49 is offline
Old 02-06-2013, 03:23 AM   #8
amc49
Fan#: 96610
Forum Activity 11%
Big dummy.................
amc49 is offline
Old 02-06-2013, 05:59 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
^^^Are you calling yourself names again since the DPFE doesn't output anything?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-06-2013, 09:26 AM   #10
Andrews-bad-SE
Fan#: 100389
I'm loving it so far haha. Cleveland rocks! Except the cold. That doesn't quite rock as much.
Posted via FF Mobile
