no spark - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-04-2013, 09:55 PM   #1
dragford
Fan#: 87718
What I Drive: 2003 silver lx
Points 263, Level 5
Points: 263, Level: 5 Points: 263, Level: 5 Points: 263, Level: 5
Level Up 26% Completed
FF Reputation: 1 dragford Good Standing Member
no spark
OK - 2003 SPI. Replaced engine with rebuilt model. Everything hooked up. Engine cranks, but will not fire. Not cranking slowly, normal. No spark from spark plug when removed and held close to manifold while cranking. Little bit crazy cuz it was running in another car. Is there ground strap other than the one that goes to the one bolt on the starter/block/bellhousing? Not sure where to start. Everything was working in other car. Can hear the fuel pump pressurize when key is turned on. What do I do?
dragford is offline
Old 02-04-2013, 10:57 PM   #2
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Did you check the plug going into the coil and check the coil as well? Also not 100% sure on this but thought I remembered the crank shaft position sensor could be responsible for spark output and not just timing as well, depending on control module.
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 02-05-2013, 04:14 PM   #3
dragford
Fan#: 87718
Points 263, Level 5
hmmmm
wondered about that. I had to splice the crankshaft position sensor wiring into the harness. the plug in the middle that joined the wire(s) to the harness was broken so I simply wired the wires together in one of those crimp connectors.
dragford is offline
Old 02-05-2013, 06:15 PM   #4
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,786, Level 54
Points: 6,786, Level: 54 Points: 6,786, Level: 54 Points: 6,786, Level: 54
Level Up 18% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Buy-Sell-Trade Rating: (23)
Solder it ASAP
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 02-05-2013, 07:11 PM   #5
dragford
Fan#: 87718
Points 263, Level 5
well
Well i worked on it again and worked on those wires again. Nothing. So i had my son turn the key as I looked. The lower damper/pulley seems to be bent and/or on crooked, as it has a little back and forth motion as it turns. Could this small irregular movement be sending a bad signal to the cps which causes no spark? I dont know how/why it may be bent, but it seems to be moving fore/aft a little as it turns.
dragford is offline
Old 02-06-2013, 08:22 PM   #6
dragford
Fan#: 87718
Points 263, Level 5
way
is there a way to check if the cps is functional?
dragford is offline
Old 02-07-2013, 03:01 PM   #7
duc450
duc450's Avatar
Fan#: 10651
Do you have any OBDII diagnostic scanners? If you have a descent one you should be able to read the crank sensot signal.
duc450 is offline
