Dealer put in wrong coolant (Gold instead of Orange) -- a problem? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-04-2013, 05:54 PM   #1
empowah
Fan#: 91459
What I Drive: Mk3
Points 700, Level 13
Points: 700, Level: 13 Points: 700, Level: 13 Points: 700, Level: 13
Level Up 34% Completed
FF Reputation: 1 empowah Good Standing Member
Hi there,
A few days ago, I noticed my coolant was below the "minimum" line, about a centimeter below. Today, I stopped by the dealer to have it topped off. The service advisor poured in some coolant slightly past the "minimum" line, and when he had finished, I noticed it was Ford Motorcraft Gold coolant.
I looked at my owners manual, and checked the coolant reservoir label, and it says that my 2012 Focus uses Motorcraft Orange coolant, and that these two fluids shouldn't be mixed.
Is this a problem? Does it need to be drained now, or is the small amount of Gold coolant that the dealer put in acceptable? It's really irritating how a simple trip to the dealer can end up being a potential headache.
Thanks,
Michael
2014 Ingot Silver - Electric (current)
2012 Oxford White SE 5-door 5M 203A + Sport Package (sold)
empowah is offline
Old 02-04-2013, 06:23 PM   #2
Kabigon
Fan#: 88299
Points 4,414, Level 42
Points: 4,414, Level: 42 Points: 4,414, Level: 42 Points: 4,414, Level: 42
Level Up 32% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by empowah View Post
Hi there,
This doesn't surprise me.
http://www.fordparts.com/Products/Ch...-Coolants.aspx
(referring to Motorcraft® Gold Antifreeze):
Do not mix different colors or types of coolant in your vehicle. Make sure the correct coolant is used. Mixing of engine coolants may harm your engine’s cooling system. The use of an improper coolant may harm engine and cooling system components and may void the warranty
Do not use this product in systems originally equipped with the orange-colored Motorcraft® Orange Antifreeze/Coolant
My suggestion is to have the dealer flush the cooling system and refill with the correct coolant. If they are uncooperative, contact Ford directly and escalate your issue with them.
I am Kabigon and I approve this message.
Kabigon is offline
Old 02-04-2013, 06:29 PM   #3
leh0825
[:)][:)][:)][:)] I got this!!!!
leh0825's Avatar
Fan#: 63206
What I Drive: 04 F250 FX4 6.0L
FF Reputation: 8 leh0825 Good Standing Member
exactly, id get it flushed as soon as possible!
Team Duratec #220/Sedan Revolution #179/NW Posse#5
Originally Posted by jmiller_1974 View Post
Geesh. I mean I know it's just a Focus to the repair shop, but they couldn't give You something other than a rolling vagina to drive?
leh0825 is offline
Old 02-04-2013, 09:14 PM   #4
Strix
Fan#: 85696
What I Drive: Not a Ford
Points 539, Level 10
Points: 539, Level: 10 Points: 539, Level: 10 Points: 539, Level: 10
Level Up 78% Completed
FF Reputation: 0 Strix Poor Behavior Needs Improvement
Another clueless dealership service department doing things wrong and messing up people's cars.
I wonder if Ford will ever do anything about this...
Yeah... I'm still regretting my fateful trip to the dealership service department last October. My car has never been the same, and I doubt that it will ever be fixed correctly.
Strix is offline
Old 02-04-2013, 09:57 PM   #5
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Buy-Sell-Trade Rating: (6)
If your antifreeze is ethylene glycol based then its fine to mix with others that are the same however things like dexcool will turn things into gel or something other. Chemicals react in mysterious ways.
Squareleft is offline
Old 02-04-2013, 10:08 PM   #6
empowah
Fan#: 91459
What I Drive: Mk3
Thanks for the input, all.
I don't have much confidence in the same dealer to flush the system correctly, make sure it's properly bled, etc. I've PM-ed FordCustomerService to see what they can do. Luckily in the Southern California region, there are at least a handful of other dealers to choose from.
At the moment, I've stopped driving the car and will pedal around in my bicycle until the system is flushed.
empowah is offline
Old 02-04-2013, 10:10 PM   #7
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,064, Level 67
Points: 10,064, Level: 67 Points: 10,064, Level: 67 Points: 10,064, Level: 67
Level Up 4% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Motorcraft Orange coolant is OAT (organic acid technology) based for extended drain intervals, and it doesn't mix well with basic green/ gold coolant in terms of the protection, nor the relationship to the metals inside the cooling system.
https://www.fcsdchemicalsandlubrican...us187175us.pdf
https://www.fcsdchemicalsandlubrican...ing%20Products
suss6052 is offline
Old 02-05-2013, 01:15 AM   #8
empowah
Fan#: 91459
What I Drive: Mk3
What's interesting is that the recommended coolant replacement intervals are 6 years/100K for the first time, then 3 years/50K thereafter.
I wonder if this is because coolant filled from the factory has a lower risk of contamination and can last longer. In that case, if I get the car flushed out, should my next change interval be 3/50?
empowah is offline
Old 02-05-2013, 09:16 AM   #9
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
...I've PM-ed FordCustomerService to see what they can do...
Michael,
Thanks for the heads up; I’ll shoot you a reply by the end of the day.
Originally Posted by Kabigon View Post
...My suggestion is to have the dealer flush the cooling system and refill with the correct coolant. If they are uncooperative, contact Ford directly and escalate your issue with them.
It’s great to see these recommendations, guys.
Originally Posted by Strix View Post
...My car has never been the same, and I doubt that it will ever be fixed correctly.
Strix,
I still have your info from before, so drop me a line via PM and I’ll help.
Cory
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 06-22-2013, 01:41 PM   #10
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
So, I check again and my coolant has been below the min line. So I stopped by the dealer this morning and picked up some coolant to top the tank off. I am glad I double checked, I was sold Gold coolant concentrate instead of Orange. The parts counter guy even looked it up and made comment to different coolants being used either in general or in the Focus. Either way the owners manual and sticker on the coolant tank confirmed the use of the Orange coolant.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
