Can rain sensing wipers be turned off? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-04-2013, 07:57 AM   #1
2k2wranglerx
Fan#: 96554
What I Drive: 2013 ST
FF Reputation: 1 2k2wranglerx Good Standing Member
I hate them. I've had them on other cars and loved them. But they just do not work on my focus. They're spastic and when you need them they shut off!
Is there a way to make them normal wipers again? When I put the selector in the "normal" range they still act as rain sensing. Augh!
2k2wranglerx is offline
Old 02-04-2013, 08:32 AM   #2
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
Really?
When the stalk is all the way down, your rain sensing wipers will stay OFF. One click up on the stalk, activates the rain sensing wipers, any further clicks up on the stalk put your wipers to manual, ie: constant speed, the more clicks up the faster they go - like on every car.
You may also want to adjust the sensitivity of the wipers by turning the wheel/knob at the end of the stalk, that may make your rain sensing wipers work better.
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards
Some Guy From NY is offline
Old 02-04-2013, 09:28 AM   #3
2k2wranglerx
Fan#: 96554
Originally Posted by Some Guy From NY View Post
Really?
my high and low constant on settings work fine. But at the first click up (the stalk) that puts it into "inter" mode pretty much means it'll be in rain sensing all the time.
From there you have the adjustable dial on the stalk. It doesn't matter what position i put that in, it's in rain sensing. even right in the middle, it'll be working fine and then the wipers will just go down (like i turned them off) until i either turn them off and on again, or adjust the dial again.
it's the most frustrating thing ever.
Old 02-04-2013, 09:32 AM   #4
2k2wranglerx
Fan#: 96554
so I thought it was supposed to be rain sensing in those 2 upper arrow areas...
but it doesn't seem to matter. they will shut off and act like rain sensing wipers in the range below those arrows as well.
Old 02-04-2013, 09:38 AM   #5
2k2wranglerx
Fan#: 96554
So basically anywhere I set that dial it acts like rain sensing.
Old 02-04-2013, 09:45 AM   #6
Some Guy From NY
Fan#: 101517
I am confused...
The only way to "turn them off" is to push the stalk down to its last position before it goes to the window washer fluid.
One click up from this last position is the rain sensing wipers. Turning the dial adjusts their sensitivity, it does not turn them off - the click of the stalk below this setting like I just described is OFF.
So what you need to do is always keep it OFF and then when you want to use the wipers, you have to move the stalk up at least 2 clicks to bypass the rain sensing wiper selection, and go to the low & high settings.
Old 02-04-2013, 09:49 AM   #7
2k2wranglerx
Fan#: 96554
Yeah mine are:
High
Low
Rain sense
Off
Mist
Is there a way to change the rain sense to regular intermittent since the rain sense sucks so bad. I can have it at any position in rain sense and they always shut off.
Old 02-04-2013, 09:50 AM   #8
Some Guy From NY
Fan#: 101517
Originally Posted by 2k2wranglerx View Post
Yeah mine are:
High
Low
Rain sense
Off
Mist
I believe you can actually unplug a cable and they do become intermittent. IT was posted somewhere here on the forums before, but I do not remember where.
Old 02-04-2013, 09:51 AM   #9
2k2wranglerx
Fan#: 96554
Ok thanks. Ill keep searching.
Old 02-04-2013, 09:53 AM   #10
Some Guy From NY
Fan#: 101517
I think the cable is under the plastic cover for the sensor on the windshield.
