#1 | ||||
SPI Parts list for head swap
Getting a list of parts together that I'll need when I start the head swap in March on the 02 SPI. It hasn't blown yet and it's on limited usage right now. Going with Heads Only the $275 version. So far this is what I have:
Head Gasket Valve Cover Gasket Intake Gasket And going to do these 2 while a part. Just changed the timing belt so will reuse it: Water Pump Timing belt tensor 375 Total so far and using all Fel-Pro gaskets. Not too bad if nothing else goes wrong in another 100k, AC is all new this year, transmission is shifting good and no rust. Anything else that I should add to the list?
91 Festiva GL 150k - auto 02 Focus LX 95k - auto 04 Escape XLT 113k |
Remove Advertisements |
Fan#: 1
#2 | ||||
Why not get the valves only head and save $50? I have bought 2 of thats guys valves only heads, pretty easy to transfer everything over. If you buy the head gasket set (I bought the one off ebay for $65 and the gaskets are quality gaskets, Eristic is the brand) it includes EVERYTHING you need for a head job including the head bolts (just be sure the listing says includes head bolts), the Fel-Pro set is nice but does NOT come with head bolts and is expensive. Also check ebay or amazon for the timing belt KIT that includes the water pump, timing belt and tensioner. Dont forget antifreeze, oil and filter. If you buy the heads only head be sure to get some assembly lube for the lifters/cam when you swap them over to the new head. PS- my 02 SPI took a crap last week at 98k miles, just got it rebuilt and running this past saturday.
So - Head gasket KIT Timing belt KIT Head Antifreeze Oil & Filter Thermostat (head gasket kit will have new gasket) |
#3 | ||||
Supposedly there is a 'NEW' cast heat for the SPI. Checkout this thread. Wish there was more testimony on them....
http://www.focusfanatics.com/forum/s...termarket+head
Member of the Dropped Valve Seat Club. Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything. 40k+ miles, now jinxed? |
#4 | ||||
BTW if any one needs good used piston/rod assemblies I have some, just PM me. |
#5 | ||||
One of the benefits of a 'New' cast head is the known mileage - ZERO. If you use your parts from your head you at least know the mileage on them too.
A rebuilt head has an unknown amount of mileage and is most likely damaged, albeit vacuum/pressure tested. Plus it is rebuilt with parts with unknown mileage. Rebuilt could mean recycled two, three or more times and populated with parts tossed into a bin/floor. This is the 'New' cast head company: J&C Enterprises Cylinder Head, 1-800-266-5599
#6 | ||||
REVOLT.BUILD.RISE
Zero mileage would be a great advantage. but 275 is not a bad price for a head.
Found out today that cruise control and autopilot are not the same thing....Shortest nap ever! Sedan Revolution#13 Rally Revolution#99 |
#7 | ||||
The guys that rebuild the heads are not going to spend the hours it takes to clean and rebuild a head if its "bad", pressure checking the head is all it needs to ensure a good head, then they mill them after the valve job for a fresh surface. They are just as good as a new cast head IMO but way cheaper. Were not driving 300+ HP performace cars that see 6k+ rpm a bunch of times daily, the rebuilt heads are fine. Get the $225 valve only heads from the bay and swap YOUR cam/lifters/rockers over, just be sure to use lots of assembly lube on the cam.
#8 | ||||
Disclaimer - I have no, had no, won't have any financial interest in the company.
From their web-site the current price of a 'New' cast head is $290. 'New' cast won't have any thread damage or won't have any stress damage in the combustion chamber or water jacket that could potentially lead to failure during future ignition, regardless of rpm. They won't have worn, oversized lifter bores.
#10 | ||||
They're on ebay. It looks like they come in three flavors right now:
$359 - Fully populated - Item number: 270789723839 $290 - Valves - Item number: 270789726680 $249 - Bare Head - Item number: 350564478176
| Thread Tools | |
| Display Modes | |
