Revo Knuckle suspension on the ST? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 02-02-2013, 02:45 PM   #1
bigdesignmachine
bigdesignmachine's Avatar
Fan#: 73457
What I Drive: 2013 Tuxedo Black ST2
FF Reputation: 1 bigdesignmachine Good Standing Member
The RS500 has this. I watched a video on Youtube last night talking about the Revo Knuckle suspension that the RS500 features and how it works to compensate for certain things during driving.
YouTube Video
The question is, is Revo Knuckle suspension possible on the ST ? I know instead of Revo Knuckle, Ford went with having the ESC help with torque steer but even with that being available on the ST, could Revo Knuckle be added ?
bigdesignmachine is offline
Old 02-02-2013, 03:27 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Waste of time if anything just get a LSD, it would cost alotttttttttttt less
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 02-02-2013, 08:43 PM   #3
bigdesignmachine
Fan#: 73457
Well until someone produces an LSD for the ST we can only dream up ideas.
And the question was more geared towards is it possible.
Posted via FF Mobile
Old 02-05-2013, 11:43 PM   #4
jsr72
Fan#: 97393
What I Drive: 2012 Focus SE
Points 151, Level 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Level Up 2% Completed
FF Reputation: 5 jsr72 Good Standing Member
Not easily. Lots of stuff got changed on the RS.
jsr72 is online now
Old 02-08-2013, 01:01 PM   #5
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
Points 1,311, Level 20
Points: 1,311, Level: 20 Points: 1,311, Level: 20 Points: 1,311, Level: 20
Level Up 11% Completed
FF Reputation: 5 finalley Good Standing Member
....Quaife does.... it's the same one as the Mondeo220.... I have it on my kitchen table right now... waiting for spring....
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
Old 02-26-2013, 12:05 PM   #6
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
The RevoKnuckle will likely be on the upcoming Focus RS, if they decide to produce it and if it comes to the US. It's one of the ways to help set the RS off above the ST aside form simply more power.
The Revoknuckle really doesn't function the same as an LSD. It's made to address a different issue.
- A LSD will help you put power down coming out of a turn. Getting power to the correct wheel.
- Revoknuckle changes the geometry of the front suspension as it attaches to the wheel knuckle to counteract torque steer.
Both would work together beautifully, but they are completely independent of one another. So yes you could put revoknuckles in a car without an LSD. Obviously having both would compliment each other better.
I would suspect to even try putting a RevoKnuckle on an ST you would have to order spare parts from Europe. Assuming you could get the Revoknuckles ordered, here's a first blush guess at what you'd have to confirm before trying it.
Compare everything that attaches to the wheel knuckle:
- Axle length
- wheel bearings
- Tie rods & ends, length fittings
- Brake caliper mounting points
- Macpherson strut mount point
- Ball joint mount
Most of that should be similar of compatible. For instance I can't imagine they moved the steering rack between the RS and the ST, so presuming tie rods would be fine, would obviously need to be adjusted. I doubt they changed the geometry of the brake caliper mounting points.
But the whole point of the Revoknucle is to change the geometry of the front suspension and where the steer points attach in relation to the axles. So you'd need to confirm that this change in geometry would be compatible with the Focus ST suspension, steering, and axles.
Assuming all that, the Revoknuckle would now compensate for torque steer. But the Focus ESC automatically uses small brake applications to counter the "feel" of torque steer. So now this system would be over compensating for the forces involved in torque steer.
So without retuning that, you'd still be using up brake pads, and not really fully taking advantage of having the Revoknuckles.
Cool idea, I'd love to see it done. Best of luck if you get serious about investigating the feasibility!
apagios is offline
Old 02-26-2013, 09:44 PM   #7
jsr72
Fan#: 97393
Points 151, Level 3
- Axle length
- wheel bearings
- Ball joint mount
Flared fenders for the wider track, different swaybar, bigger rotors...
ESC uses braking for yaw stability. The ST uses the electric steering system to provide additional steering assist to help compensate for the steering torque felt by the driver.
Revo knuckles do not eliminate torque steer - they help reduce it in the same way a double wishbone does. Left-right asymmetries will always be present in the chassis.
jsr72 is online now
Old 03-28-2013, 10:59 PM   #8
Frankenbike
Fan#: 101739
What I Drive: 1995 Pontiac Trans Am, 2000 Harley
FF Reputation: 1 Frankenbike Good Standing Member
When it comes down to it, the RevoKnuckle is a mini double wishbone suspension. It nullifies camber.
Now if they had an electric clutch driven mechanical LSD, they could use that for torque steer compensation by directing torque to the wheel on the outside of the curve caused by the torque steer.
They're going to have to throw every trick they have in the book to deal with an FWD car that delivers 325+ hp, which will want to rip your tendons apart with epic torque steer.
Frankenbike is offline
Old 03-28-2013, 11:24 PM   #9
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,029, Level 74
Points: 13,029, Level: 74 Points: 13,029, Level: 74 Points: 13,029, Level: 74
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 99%
It would have been cool for ford to put the revo knuckle on the st, but the bean counters put the ckubosh on that. The less parts difference between the regular & st foci's the better. I like mechincal grip over electronics, myself. I like more edge to it. It is a performance car & should have more edge to it & less electronics.
felixthecat is online now
