SPI Maintenance - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-03-2013, 03:00 PM   #11
shjeeper
Fan#: 66435
What I Drive: 2002 Charcoal Ford Focus SE 2.0 SPI
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
FF Reputation: 1 shjeeper Good Standing Member
Got the head switched out.. The head from headsonly worked out great. I also replaced the timing belt tensionor, water pump, timing belt, and IAC. Of course, everything else was cleaned out the best I could. I've put about 400 miles on it, and will check the compression here in a couple days.
Now however, it revs up to ~2k rpms on a cold start for about 5 seconds. Afterwards it knocks back down to about 1400 rpms like it always did, until it's warm and levels out at around 700-900 rpms. Any ideas?
shjeeper is offline
Old 03-04-2013, 11:48 AM   #12
shjeeper
Fan#: 66435
Points 335, Level 6
So I got the scanner out and found out my RPM's were actually jumping to 3k at start up. I subscribe to the theory that the most engine damage is due to startup wear, so I wanted to fix this ASAP.. I yanked the new IAC out and put the old one back in after a thorough cleaning. It works just fine now.
Autozone just gave me a $100 gift card because one of their parts cost me $100 from Ford for them to tell me it was wrong... their motor mount has been causing me troubles, and now their IAC is defective, go figure.
shjeeper is offline
Old 03-04-2013, 03:15 PM   #13
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
Stay away from Duralast parts! If you can spring the extra bucks NAPA has quality parts that are usually made in the US.
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
Old 03-04-2013, 05:14 PM   #14
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,806, Level 100
Points: 36,806, Level: 100 Points: 36,806, Level: 100 Points: 36,806, Level: 100
Level Up 0% Completed
Duralast is ok, it kinda like needing a family car or a work truck and you go buy a GM product. It will get you by but its cheaply made and will fail sooner than later.
Napa isn't worth the price. Just get motorcraft and call it a day. Rockauto.com sells oem parts like motorcraft for way cheaper than you can buy at a ford dealer.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is online now
