2000 2.0l zetec vibrates at idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-01-2013, 02:50 AM   #1
nick.ford
Fan#: 104316
What I Drive: 2000,silver,se-focus
FF Reputation: 1 nick.ford Good Standing Member
2.0l zetec automatic
hi have replaced the
timing belt
ignition coil
plugs&wires
dpfe
catalytic converter
both o2 sensors
head temp sensors
fuel filter
compression showed 150psi on each cylinder
it vibrates as if i have a balance shaft misaligned
i'm thinking about double checking my timing
nick.ford is offline
Old 02-01-2013, 02:52 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Your motor mounts are most likely the cause, especially the passenger side one. There are quite a few threads about it.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 02-01-2013, 03:01 AM   #3
nick.ford
Fan#: 104316
it seamed fine when i changed the timing belt. i didn't see any oil leaking out of it. i guess ill replace it. what would you recommend polyurethane or OEM hydraulic. the dog bone felt good.
Old 02-01-2013, 03:43 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
Most say get the factory one, and sometimes they can look ok from the outside and sometimes you can see them split from the metal. Most of the time the liquid leaked out a long time ago. For the lower dog bone I recommend getting the energy suspension ones but they may keep some of the vibrations that your trying to get rid of, but then again it may feel a 100% better when replaced with a new passenger side one at the same time. My car smooth enough for me, except when I blow the passenger side one up.
Moderator for
Technical Chat
Old 02-02-2013, 03:04 AM   #5
nick.ford
Fan#: 104316
ok so i put a new motor mount in. it helped the vibration while in park but
when its in gear it shakes/vibrates like it is missing. it has 140k in it.
i was wondering if it could be an injector issue. o... and its averaging
22-24mpg i thought it was low.
Old 02-02-2013, 04:28 AM   #6
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
On these cars the best is to replace the passenger motor mount with one from Ford you can use the aftermarket parts for the dogbone and transmission mount. It's best to replace all 3 mounts at a time. The aftermarket passenger mount isn't very good and you only save about $30 on it.
tmittelstaedt is offline
Old 02-02-2013, 05:52 AM   #7
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Amen to that...............if you used anything other than Ford mount on passenger side get ready to buy another one just like so many before you............
amc49 is offline
