2001 focus zx3 manual trans clunking barely engages - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2013, 01:07 PM   #41
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
Well I got the whole thing reassembled with the exception of battery and tray, as I'm going to bleed the clutch today. Unfortunately it's Easter and of course Sunday, so the dealership is closed and the auto parts stores around here don't carry a synthetic manual trans fluid that will work with the mtx-75... so I guess I'm stuck for another day. I could probably get away with a synthetic ATF, as it appears that's what was in it before, but I might as well do it once and do it right. I went ahead and put new struts on the front while I had it apart, and replaced the lower transmission mount. So this thing should be tip top once I get the fluid changed. My goal was to have it going this weekend though, I'm disappointed this fluid isn't easier to track down.
FoMoCus is offline
Old 03-31-2013, 01:32 PM   #42
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,797, Level 73
Points: 12,797, Level: 73 Points: 12,797, Level: 73 Points: 12,797, Level: 73
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 99%
Worth it to "Hurry Up & Wait", as the stock trans fluid isn't an ATF type....
sailor is online now
Old 03-31-2013, 08:27 PM   #43
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Synthetic ATF? Well, whatever you choose: Make sure it's at least DOT 3 or DOT 4 compliant (recommended: Super DOT 4 for MTX-75's).
I'd quote the 2001 Ford Focus manual, but, I'm sure you could just as easily look it up.
Pretty much EVERY auto-parts store I know of carries one of those three.
Oblivion is offline
Old 04-01-2013, 12:17 AM   #44
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Read too fast...
Thinking ONE of us read too fast oblivion, while he mentioned bleeding the clutch I'm pretty sure the OP was referring to getting the right fluid to refill the transmission....
Old 04-01-2013, 01:06 AM   #45
Oblivion
Fan#: 92148
I disagree. He made no mention of the gearbox fluid. He specifically said "bleeding."
as I'm going to bleed the clutch today. Unfortunately it's Easter [today] and of course Sunday
According to the owner's manual: Mercon ATF (Ford part number: XT-2-QDX) is what you're supposed to use (2001 Ford Focus).
Oblivion is offline
Old 04-01-2013, 01:48 AM   #46
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Easy there! I was putting my comment politely, as opposed to telling you that you were mistaken!
The Synthetic fluid to refill the transmission, as mentioned by the OP, would be Ford Synthetic Manual Transmission fluid - Mercon ATF would be for an automatic, not an MTX-75.
DOT 3 or 4 you mentioned would refer to brake fluid for the clutch bleeding, ATF wouldn't be involved there at all!
Cheers!
Old 04-01-2013, 02:23 AM   #47
Oblivion
Fan#: 92148
Cheers!
I was also politely replying.
No. Mercon ATF is for the MTX-75, IB-5, and Automatic. Have you not read the owner's manual ever before?
ATF (automatic transmission fluid) is only a DOT (department of transportation) fluid. They are nothing different.
You use ATF fluid (Mercon IV?) for your power steering fluid. If you want to refer to it as DOT fluid: Be my guest.
XT-2-QDX (Mercon ATF) is your "power steering" fluid on a Ford Focus.
The brake / clutch fluid share the same reservoir externally. They have individual components though.
Bleeding the brakes will inevitably bleed the clutch as well. But bleeding the clutch alone will not affect the brakes.
ATF (DOT fluid) is what you use for brake / clutch fluid.
Oblivion is offline
Old 04-01-2013, 02:51 AM   #48
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
1. By the time my '04 was built, Ford was using the Synthetic Manual Transmission Fluid I mentioned as the Factory Fill. Yes, it's described as such in the owner's manual. This is the fluid commonly recommended here for this transmission over "experimenting" with other brands & types since it's been proven to work well.
2.ATF is a DOT fluid? Please explain how ATF & brake fluid are not different.
3.Yes, I use Mercon ATF for my power steering. hadn't referred to it at all!
4. Bleeding either clutch OR brakes will not affect the other, as long as the shared reservoir is kept filled. Clutch WILL "suck air" first if the fluid level is too low, by design you loose clutch B4 you loose brakes in the case of low brake fluid.
5. Good luck if you want to use ATF for brake/clutch fluid, they aren't compatible!
Old 04-01-2013, 06:20 AM   #49
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
Y'all need to leave that alone. I've seen a lot of disparity between fluids that people use in the MTX on here. Some people use synthetic ATF, some people use synthetic 75w gear oil. Of course, there are those who use all sorts of stuff made by aftermarket companies, and then there are those that use Ford synthetic manual transmission fluids like the one recommended for my transmission.
In my 9 years or so on this site, I have not known of one MTX failure due to improper fluid fill. That's just FYI, ok. I'm not trying to get some sort of freaking oil controversy started on here. We have plenty of those threads if you search.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-01-2013, 04:20 PM   #50
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Yah, makes sense - didn't want to start another oil debate!
Got worried about ATF = Brake Fluid though....
Cheers!
