2001 focus zx3 manual trans clunking barely engages - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-31-2013, 06:26 PM   #1
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
I figure this is the best place to post this. I'm new to the forum as I just got this car today. Bought it from a friend because it needs transmission work. The car starts fine, the clutch seems fine (fair amount of pressure and pedal movement), but if you try to put it in gear and let up on the clutch pedal, there is a pretty loud clunking type noise coming from the transmission when the clutch is fully engaged. I wouldn't call it grinding, it almost sounds like something is getting slung around in the bellhousing maybe. Most of the time it won't engage at all, but every couple times you try, it will grab in gear but it slips and doesn't fully engage.
The p.o. took it to my personal mechanic and a transmission shop. They both said about the same thing, it's going to be hard to tell without pulling the trans. The transmission shop said transmission, my mechanic said maybe differential. I'm thinking about tackling the job myself but I haven't been able to find anybody with this same problem researching it. I'm wondering if maybe the clutch plate actually broke and parts of it are getting thrown around. But I've never seen that. I've read about the shift cables stretching or breaking, but this noise isn't a grinding, its more of a clunk or knocking. I also read about a roll pin shearing, but I don't know that it would sometimes slightly engage if that were the problem. Any ideas on where to start before I tear the whole front end apart?
FoMoCus is offline
Old 02-01-2013, 12:02 AM   #2
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Buy-Sell-Trade Rating: (6)
Ive seen the pressure plate break around the springs allowing one of the springs to pop out. ive also seen a tab break off of the throwout bearing. See this all the time on hondas. dont see why ford would be immune to this problem. Its just abuse or the lack of knowledge how to drive. The only way to tell is pull the transmission out.
if it were a differential problem i think you would feel it or here it like a couple broken teeth on the ring gear. constant popping while driving. if its a wallard out diff then i think you would feel a ton of slack while letting off gas and getting on it.
Squareleft is offline
Old 02-01-2013, 06:22 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
You needa new clutch.
On Fords, I highly suggest purchasing a slave cylinder, and replacing that also. Our slaves are plastic, and it's a good idea. Hopefully you get in there and you won't have to replace the flywheel. If you do replace the flywheel- Be SURE to purchase flywheel bolts. These are stretch to fit bolts like head bolts, and will not work a second time. You might also want to locate a tap to clean the threads out, or clean off one of the old bolts- then use it multiple times in each hole to clean the blue threadlock out of the threads.
Another good thing about replacing the slave cylinder is that it will come with the throw-out bearing glued to it. You can throw away the bearing that comes with the clutch kit. This will prevent a rattly knocking sound that happens because the throw-out bearing is rattling between the pressure plate and the slave cylinder after the glue wears off. It's just a sound- that goes away when you press the clutch pedal, but it freaks some people out.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 02-01-2013, 02:43 PM   #4
gonefishn1212
Fan#: 109215
What I Drive: 03 silver zx3
FF Reputation: 1 gonefishn1212 Good Standing Member
sounds like my problem cept i have no clutch pedal pressure, to drive the car i have put in 1st gear and start the car...a "self jump start" and to shift i have to rev the rev the engine... i have no clutch lol... and i hear clanking and rattling like u would if you had put rocks in a plastic bottle and was tumbling end over end noise when driving it. ive got a clutch kit w/flywheel coming for 330 buck its a LuK clutch kit Part Number: 5420-07083878 (from parts geek.com)
i hope to god this is the right thing/part(s)
gonefishn1212 is offline
Old 02-01-2013, 04:54 PM   #5
FoMoCus
Fan#: 109390
Points 369, Level 7
I don't know if you can feel anyhing in the pedal, as I haven't driven it. But the sound could possibly be broken teeth. There's almost no way of letting off the gas and getting on it, because the clutch rarely engages and when it does it doesn't "grab" like it should. I am hoping for just the clutch though, as that's the cheapest of the problems.
FoMoCus is offline
Old 02-01-2013, 05:05 PM   #6
FoMoCus
Fan#: 109390
Points 369, Level 7
Thanks for the tip on the flywheel bolts. And yea I definitely would replace the slave. I hate fords internal slaves. I had the slave fail on my ranger and F-150. Gonefishn, that noise description isn't too far off from mine haha. Let me know what happens when you crack yours open.
My debate now is to try and yank the transmission on my own or just take it in. If it was real wheel drive it would be no question, but on this thing the tight space seems like a pain in the rear.
FoMoCus is offline
Old 02-01-2013, 07:36 PM   #7
gonefishn1212
Fan#: 109215
Ill let u know what i find/see ill be opening it up in the morning just got the parts in.
Old 02-02-2013, 01:11 AM   #8
FoMoCus
Fan#: 109390
Points 369, Level 7
I'm not getting mine to the garage until tomorrow. Or today I guess, since its 1 a.m. Then I have to decide if I want to break it apart on my own.
FoMoCus is offline
Old 02-02-2013, 04:45 AM   #9
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
It is fairly easy to replace the transmission. It only took me 2 weekends and I only did it that way because I didn't want to buy any new parts until I had got the trans out. I did a writeup on it here:
http://www.mittelstaedt.us/
There's a video on youtube to replace the clutch on this but I don't care at all for the way the guy gets the trans out, he does not drop the subframe, and to get the trans out that way you have to turn it and you have very little clearance. he also pries it sideways and it falls down on the floor. It's a lot easier to drop the subframe about 4-6 inches then you have plenty of room to work.
If it was me I would scout a used trans from a wrecker these transes are common. I doubt you have a clutch problem, sounds to me like the clutch is working fine and a gear inside the trans is broken.
tmittelstaedt is offline
Old 02-02-2013, 11:20 AM   #10
FoMoCus
Fan#: 109390
Points 369, Level 7
That's an excellent walkthrough on your website. You mention at one point, that the clip holding the drivers cv can break and cause major problems. The driver cv on this car was replaced about 8 months ago. I'm wondering if that clip was damaged and broke. What problems would that cause?
FoMoCus is offline
