Ugh! Yet another issue with my focus! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-31-2013, 03:32 PM   #1
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,445, Level 65
Points: 9,445, Level: 65 Points: 9,445, Level: 65 Points: 9,445, Level: 65
Level Up 32% Completed
Forum Activity 8%
My most recent issue I am having with my focus, adding to a very very long list, is that now it drains the battery when parked. I have absolutely no clue as to why either. no lights are on in the car and I have no radio at all anymore(removed it). I noticed when I shut the car off the temp and fuel gauge will jump back to where they last were(i.e. warm for temp gauge and whatever fuel level is in the car). Does anyone have any idea what would cause this?
EDIT: So i had the car running for a little while shut it off and 5 mins later it was flat again...
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is online now
Old 01-31-2013, 04:51 PM   #2
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
a bad battery/alternator notwithstanding, do you have access to a DC ammeter? That and some fuse-pulling might help you narrow it down.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 01-31-2013, 05:02 PM   #3
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,285, Level 67
Points: 10,285, Level: 67 Points: 10,285, Level: 67 Points: 10,285, Level: 67
Level Up 59% Completed
Forum Activity 18%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
how old is battery
pasta is offline
Old 01-31-2013, 06:27 PM   #4
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
Get your alternator tested ASAP. It's probably in the way out. Mine just died in my 06 ZX4, they may be approaching end of life.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 01-31-2013, 06:52 PM   #5
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 8%
Nope at charging it shows 14.8 volts. I may have to go the route of fuse pulling and checking. Battery is two years old and this problem just started. The car usually sits two to 3 months due to its other issues. ( clogged cat, terrible idle, no winter tires. )
Old 01-31-2013, 11:30 PM   #6
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 8%
So I charged the battery with a charger up to 12v. I unplugged it and stuck on my voltmeter. It drops voltage at .01 a second... disconnected the batter from the car and it still drops voltage but much more slowly. I think the battery is bad amongst something in my car drawing power off of it. I hooked back up and it no longer dropped outrageously fast. Further testing will have to be done later.
Old 01-31-2013, 11:35 PM   #7
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
To test for a draw you need to properly set up your meter to measure amperage, not voltage. Disconnect the negative cable and put one probe on the negative post and the other on the negative cable and this will give you a readout of how many amps the car is pulling. Use alligator clips and then let the car sit there a while to let all the modules go to sleep. Ensure the doors are all closed and the key is out of the car.
However your issue just sounds like a bad battery. The fact that the voltage is visibly falling while the battery is out of the car means its just unable to hold a charge.
jetrinka is offline
Old 01-31-2013, 11:41 PM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 8%
That's my thought too. It is four years old with a ton of start stops. It just crapped out with zero warning. First time that's happened to me.
Thanks for the tip on draw. I'm not much of an electrical guy. I usually try to avoid things that involve it at all cists
Old 02-01-2013, 12:10 AM   #9
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Parasitic draw test is the only way to find out how many milliamps are being used like jetrinka said. i think the acceptable amount of draw is 50-ish milliamps. if a relay is active you'll see a serious increase in milliamps. in the hundreds which is highly unacceptable. if you see that it is reading high after letting the car sit for 10 minutes to let the computers rest, then my suggestion is to start pulling relays to fine point the area. youll need an ETM to trace it back.
Squareleft is offline
Old 02-01-2013, 12:53 AM   #10
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 8%
Etm?
