Audiophile 9006: Best FM transmitter for iPods? Other Ipod connection options? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-30-2013, 01:46 AM   #1
SVTKarma
SVTKarma's Avatar
Fan#: 87870
What I Drive: 04 Orange SVT/EAP; 04 YellowSVT/EAP
Points 950, Level 16
Points: 950, Level: 16 Points: 950, Level: 16 Points: 950, Level: 16
Level Up 50% Completed
FF Reputation: 1 SVTKarma Good Standing Member
Looking for some recommendations to get Ipod connectivity to the SVT 9006 stereo head unit. Any recommended FM transmitters that really deliver clear sound? Any way to hard wire and make an AUX input?
Focus Fan in VA
SVTKarma is offline
Old 01-30-2013, 03:58 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,507, Level 100
Points: 138,507, Level: 100 Points: 138,507, Level: 100 Points: 138,507, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
Moved to the car audio section
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 01-30-2013, 07:11 AM   #3
SVTKarma
SVTKarma's Avatar
Fan#: 87870
My mistake. Thanks.
Focus Fan in VA
SVTKarma is offline
Old 01-30-2013, 07:36 AM   #4
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
don't use a wireless fm transmitter. they all suck. if you really wanna keep the factory unit then use a wired fm modulator. plugs in through the antenna. same concept with better results. you'll just need the modulator and forward and reverse antenna adapters to make it work. however i would still recommend just doing an aftermarket headunit. the best options and not much more cost for a basic one. will also get you better sound quality overall.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 01-30-2013, 08:22 AM   #5
SVTKarma
SVTKarma's Avatar
Fan#: 87870
Good information. I would like to keep the stock head unit, unless there is an aftermarket one that looks like a perfect mate to the SVT dash. Maybe I need to open a new thread for replacement head unit suggestions. Thanks.
Focus Fan in VA
SVTKarma is offline
Old 01-30-2013, 08:30 AM   #6
Kipp
Kipp's Avatar
Fan#: 31300
check out the first thread in here the headunit gallery. plenty of pics in there to give you an idea of what's available.. or you can always do a remote location install such as mounting the headint in the glovebox or somepleace else. factory look with aftermarket performance.
Midwest Crew #22
Kipp is offline
Old 01-30-2013, 09:06 PM   #7
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Forum Activity 7%
FF Reputation: 8 Milton Good Standing Member
Adding an Aux Input
Here are two methods:
Originally Posted by Milton View Post
So I have a 2007 Ford Focus 4 door. Stock radio with buttons for satellite radio. I went to http://www.installer.com/ and installed:
* USASPEC PATFORD1
--- DISPLAYS TEXT, ARTIST, PLAYLIST, ALBUM and SONG TITLE INFORMATION
--- Charges your ipod
--- hide the ipod in your glove box, control it from your stock head
--- provides a aux input in addition to the ipod interface
* IS335 Isimple dash panel mount audio input kit
--- Drill a small hole in the stock radio bezel
--- female connector slides into the hole and the attached cable connects to the aux input jack on the PATFORD1
The result is the radio looks completely stock except for the AUX input jack.
This method works with just about any radio, any car:
First create an aux input to your radio:
This is an "IN-LINE" fm transmitter, meaning your radio antenna plugs into it, and then it plugs into your radio. The sound quality is as good as a strong FM radio signal. It does not interfere with your FM reception, it just "adds" a new station. The frequency of the new station has two options. I got mine from www.installer.com
Second, make that Aux input a dash mounted 3.5 MM stereo jack. Use an IS335 Isimple aux input dash panel kit:
The FM Transmitter provides you RCA input jacks. This accessory lets you convert those RCA jacks to a dash mounted 3.5mm stereo jack. Just requires drilling one small hole for the jack. I got this from www.installer.com
At this point you have an aux input, but you want to connect up that IPOD. Just add a Monster Cable Ultra-Low Profile iPod iCharger (AICHG2 IP)
* Add a 12volt cigarette lighter socket that is powered only when your radio is powered.
* Plug this charger into the above socket
* This charger provides a true "Line Out" that you connect to the Isimple Aux Input you installed above.
* What's neat about this charger is not only does it charge the iPod and provide a line out for the aux input, but when you turn off the ignition the radio and the iCharger loses power, the iCharger signals the iPod to go to pause. You go into the store, come back out, start the car and then press the play on the iPod. The iPod picks up right where you left off. I got this from Amazon.
And no, I do not work for www.installer.com, just a very satisfied customer. I have used them for 4 different installs and never been steered wrong.
Milton is offline
Old 01-30-2013, 09:23 PM   #8
SVTKarma
SVTKarma's Avatar
Fan#: 87870
Milton, thanks for reply and the photos. I like it. A lot. I have an 02 Camaro SS (another wheeled passion, along with 3 SVT Foci), and it has the FM transmitter for iPod connectivity, installed by prior owner. Works great, but not sure if Audiovox unit--I will check. Until I saw your post and photos, I didn't fully understand the wiring. Now I do.
And your comment about signaling the iPod to go pause, when ignition is turned off, is important. Thanks.
Focus Fan in VA
SVTKarma is offline
Old 01-30-2013, 10:45 PM   #9
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,605, Level 43
Points: 4,605, Level: 43 Points: 4,605, Level: 43 Points: 4,605, Level: 43
Level Up 28% Completed
Forum Activity 3%
FF Reputation: 28 ah1f39 Great Standing Member
The iSimple IS77 is the best. Stay away from Scosche.
http://www.ebay.com/itm/ISIMPLE-IS77...item43b6b5fccb
ah1f39 is offline
