Weird Rattling Noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2013, 10:49 PM   #1
tylerdetox
Fan#: 109283
What I Drive: 2001 Ford Focus ZTS
FF Reputation: 1 tylerdetox Good Standing Member
Hello,
I have a 2001 Ford Focus ZTS (5 spd, Ztech DOHC 2.0 L) that I Just bought from a Dealer with only 191,036 KM on her. She has been Running Beautifully
But just recently I have been listening to it more carefully to hear anything is not normal.
I Found that my Ford will Rattle when First taking off (1st gear) and When up-shifting Rattles too. (Low RPMS, between 815 - 1500) also Will sometimes Rattle when in Idle with Foot off Clutch, but when I put my foot on the Clutch the Rattling Goes away.
Im hoping it is Nothing Serious, I will post some links to the Video's I Have done tonight with the Noises. (I Talk a lot, so ill just Post the Times of the Sounds)
Video :
http://youtu.be/PEstyHwpKBU?t=1m25s (Rattle when in Idle)
-Hoping its just a TOB or something as simple as a Heat Shield
http://youtu.be/PEstyHwpKBU?t=4m30s (Rattling when Low RPM/Shifting)
-Hoping its just something Simple...
http://youtu.be/nuOhG-okxMs?t=20s (Rattling at Low RPM 2)
http://youtu.be/nuOhG-okxMs?t=45s (Rattling at Low RPM 3)
http://youtu.be/nuOhG-okxMs?t=3m55s (Going up Driveway Rattle)
The Rattling is Just Noticeable when the Radio is off, and the Blower Fan is off and it is Audible within the Cabin.
Help me out please! As I don't feel like spending money at a dealership to get it looked at, although I will if necessary!
tylerdetox is offline
Old 01-29-2013, 11:59 PM   #2
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Interesting ... a couple of things come to mind.
Well, on my SVT when I first got that chatter, it was the heat shield hitting the exhaust.
So, do you have any loose items in your engine that you have checked?
Second, was the thought of a maybe a light weight flywheel or upgraded clutch.
Because it sounds like Clutch chatter ... common sound on upgraded clutches.
But I have also read that could be the clutch springs may not be pushing as good as if new.
These are suggestions, and hopefully you find your issue with not much hit to your wallet. And hopefully others will suggest some other theories to help you out.
Good luck.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 01-30-2013, 07:30 AM   #3
tylerdetox
Fan#: 109283
Good luck.
Ray
I'm hoping its just the heat shield, what am I looking for under the car or in the engine bay?
Thanks for the help
Old 01-30-2013, 12:21 PM   #4
tylerdetox
Fan#: 109283
Also should state that the rattling sound, sounds like its coming from the left side (driver side)
Suggestions Anyone?
Old 01-30-2013, 01:52 PM   #5
mark3inline
Fan#: 19701
What I Drive: 04 Wht ZTW
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 3 mark3inline Good Standing Member
Rattling Noise
Does it also happen when not in gear ? Have you checked upper trans mount (drivers side), and lower dog bone trans mount ? Either could be to blame for dampning problem.
mark3inline is offline
Old 01-30-2013, 01:58 PM   #6
tylerdetox
Fan#: 109283
The rattling at low rpm doesnt happen unless the tranny has been engaged (in gear) neither does the idle tick..
And no I havent checked just yet. I will do in a bit.
Thanks
Any other suggestions would be great as well :)
Old 02-01-2013, 10:22 AM   #7
tylerdetox
Fan#: 109283
So I checked the engine bay and nothing is loose or anything.
Looked under the car and saw my heat shield there but doesnt look loose.
Any suggestions? Sorry first time owning a car (just don't want it dieing on me)
Old 02-01-2013, 12:21 PM   #8
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
Originally Posted by tylerdetox View Post
So I checked the engine bay and nothing is loose or anything. Looked under the car and saw my heat shield there but doesnt look loose.
not sure the location you're referring to...on my hatchback, there is a heat shield near the gas tank; brackets look tack-welded and easily break, might not be obvious from a cursory examination. If that's your culprit, you might hear rattling when driving over bumps or potholes, and is a very simple jury-rig fix.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-01-2013, 02:36 PM   #9
tylerdetox
Fan#: 109283
It only happens at low rpm when shifting from 1-5th.
Still can't see it. There is one in the middle by where my gear shifter is. Maybe that's it
Ill take a video and post it tomorrow.
Old 02-02-2013, 08:33 PM   #10
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
A few people on this forum have talked about the throwout bearing rattling, that could be your noise. Try searching the forum for throwout bearing chatter
FoMoCus is offline
