Outside Temperature Incorrect - 2012 Focus - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-05-2013, 05:40 PM   #41
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,243, Level 100
Points: 73,243, Level: 100 Points: 73,243, Level: 100 Points: 73,243, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
I usually just use my handy, dandy Weather Channel app on my phone to obtain weather info such as temp, wind, etc. Using this info, along with some general knowledge that water freezes at 32*, I can then apply it to figure out if there will be ice on the road or not. Just sayin'.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 04-05-2013, 10:41 PM   #42
amc49
Fan#: 96610
Points 3,195, Level 34
Points: 3,195, Level: 34 Points: 3,195, Level: 34 Points: 3,195, Level: 34
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
FF Reputation: 25 amc49 Great Standing Member
Yep. Weather channel rules. It wouldn't matter one whit if the gauge is within 2 degrees, ice forms at 32 and not 33 but at the measured LOCAL SPOT only. Here in Texas ice can be on overpasses with wind and 34 temp listed on anything you want to read. Meaning something like wind chill going on there. Temperature can vary up to 5 degrees easily just depending on where you are in the city, the northern reaches of Fort worth here always have plenty of accidents because flat and not much building there to break the wind. Elsewhere in city no ice at all but same temp everywhere there, just local spots vary. Common, the outlying regions get worse because less concrete to radiate heat and less traffic to keep condensation scrubbed off overpasses and outer highways. Concreted areas can be 33 at the surface and the air 12 inches higher above is 25, dead accurate gauge will not help you there.
Car temp gauges are absolutely worthless for determination of road condition. So is a single weather report. One learns to use EVERYTHING to determine that, meaning look at the cold front on the weather for effects in other states before it gets to you, you can tell pretty much how much trouble you will have. NOAA invaluable for that. That plus your realtime temp and wind, plus listening to traffic data, plus time the ground has been above or below freezing point, and you can make a pretty much bulletproof guess on what the driving conditions are.
That someone would seriously consider dumping a car over a temp gauge, well, I won't say what I think about that. If that important, I certainly would be looking for a stand alone certified scientific measuring instrument instead of relying on junk.
amc49 is online now
Old 04-06-2013, 02:57 PM   #43
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Anyone happen to catch the story recently about next gen smart cars in the not too distant future that will collect weather data and transmit that to roadside towers along with embedded sensors. Then to a data center that processes the information and sends it back to drivers warning them of black ice/fog and other current/pending weather conditions. The story mentioned weather is the main cause of vehicle accidents and death. It was relating to that 75 car pile-up in recently in Virgina due to fog.
I don't know about you but distractions have to be catching up with weather. Grandma and grandpa are overwhelmed with every new car purchase.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 06-25-2013, 06:28 PM   #44
bwolper
Fan#: 66602
What I Drive: 2012, black, 4dr sedan, Titanium
FF Reputation: 1 bwolper Good Standing Member
I have a 2012 Focus Titanium. I have noticed that the thermometer in my car is actually 10 degrees higher. I just wanted to let you know that I am having a problem with mine too. I am going to take it to the dealer and see what they can do. Perhaps they will change out the mirror assembly. I hope they do something. I just like to look at it and know that it is accurate within 2 or 3 degrees. Ten degrees off is a bit much for me.
bwolper is offline
Old 06-25-2013, 10:05 PM   #45
amc49
Fan#: 96610
Forum Activity 54%
Yes, ten a bit much. I used to have one car ages ago with a $5 gimmick plastic clunky thermo that actually was pretty dang close and for the long term. Not like it's not doable. It finally caved in from slow melting after several Texas summers. First time I ever realized it can hit 140F in a car interior.
amc49 is online now
Old 06-26-2013, 09:27 AM   #46
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,284, Level 35
Points: 3,284, Level: 35 Points: 3,284, Level: 35 Points: 3,284, Level: 35
Level Up 56% Completed
Forum Activity 18%
Let us know how things go at the dealership, bwolper. I'm also happy to check out ways to assist, just send me a PM with your information and I'll get to work. Please be sure to include your VIN, dealer, mileage, daytime phone number, and full name.
Thanks!
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 07-07-2013, 12:33 PM   #47
bwolper
Fan#: 66602
Outside Temperature Incorrect-2012 Focus Titanium
Thank you, Chystal. I'll be sure to do that.
bwolper is offline
Old 07-07-2013, 05:25 PM   #48
gavin_eakins
Fan#: 46659
What I Drive: 2005 focus, for Lotus 7 replica
FF Reputation: 1 gavin_eakins Good Standing Member
Originally Posted by kemoe View Post
which is hard to believe that Ford's software developers couldn't do basic math. But you never know?
This isn't as crazy as it sounds!
See post #4 of http://www.focusfanatics.com/forum/showthread.php?t=254406
Cheers - Gavin
gavin_eakins is offline
Old 07-07-2013, 06:09 PM   #49
CriticalMass
Fan#: 63989
What I Drive: 2009 Focus Coupe SES, Silver
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
FF Reputation: 2 CriticalMass Good Standing Member
Originally Posted by Joeywhat View Post
Remember that the thermometer is under the passenger mirror, and can show higher or lower temps if it's getting direct sunlight, or in the shade, etc.
This.
I have never really found car temp sensors to be accurate because depending on where they place the sensor it can be affected by sunlight, shade, or in the case of older vehicles, engine heat, etc.
2009 Ford Focus Coupe SES -- What I don't know about modern cars would fill up a good sized country, but what I don't know about 50's and 60's Ford engines, would fill up a 4 oz glass.
CriticalMass is offline
Old 09-19-2013, 02:39 PM   #50
smakin
Fan#: 119072
What I Drive: 2012, yellow blaze, Focus SE
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 1 smakin Good Standing Member
Mine is out more that 15 degrees Celsius. Is there any chance that this sensor / information is used for anything else in the car? temperature of intake air?
It is a little sad to know that something that should be so easy to make work somewhat well isn't. The "who cares?" attitude about this doesn't reflect well on the rest of things.
smakin is offline
