Old 01-30-2013, 04:54 PM   #21
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3
FF Reputation: 26 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (44)
Originally Posted by kemoe View Post
Thanks for helping out.
Is this Forum for posting and resolving issues and questions or for attacking people who have found problems with their cars?
Request: Unless you can add useful input to this thread please refrain from adding useless text. I am hoping I can get this resolved and make the information available to other Focus owners. As an owner of two Fords and a fourth generation owner of Ford stock, it isn't in my best interest to try to get my car declared a lemon because of an incorrect outside temperature reading.
They have tried to help you but when you just disregard their advice it kind of ticks them off. I can tell you for a fact that these temperature sensors are never really accurate. You can check different thermometers, weather stations, National Weather Board, online temperatures or any of those other means and not all will have the same temperature. I personally have never relied on a thermometer to tell me if it is going to be icy conditions outside or not.
If you have a legitimate problem with your car, then take it to your local dealership and explain your problem to them. Your car is still under warranty and I suggest you use it. To trade in the car and lose over $5,000 on the value by trading it in for something else will only make it worse for you. You will be paying more for another car that also has an inaccurate temperature sensor. So you can see where I am going with this already, saying that you are going to get rid of a car because of a temperature sensor that is only 2-6 degrees off is very petty.
zetecDon is offline
Old 01-30-2013, 09:20 PM   #22
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
FF Reputation: 200 warneej Excellent Standing Memberwarneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I have never seen a bank marquee temperature reading to be anywhere near accurate.
What a ridiculous thing to complain about.
Looking for 17x8 wheels to race on! PM me if you have something!
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 01-30-2013, 09:46 PM   #23
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
FF Reputation: 18 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (11)
^^ Right, I can drive down a city block and all the marquees have a different temps.
EAP with 1/3 of the cold weather package. No block heater or TCS.
Sniper Focus is offline
Old 01-30-2013, 11:07 PM   #24
Chick
I like cake
Chick's Avatar
Fan#: 151
What I Drive: '11 Fiesta SES, '13 Civic Si Sedan
FF Reputation: 133 Chick Excellent Standing MemberChick Excellent Standing Member
Buy-Sell-Trade Rating: (37)
^This. My '07 Civic had a temp gauge was never accurate, nor are either one of the Fiestas that are in my family.
February 2005 ROTM
2011 Yellow Blaze Fiesta SES
2013 Taffeta White Civic Si sedan
Focus Fanatics Forum Rules
Ride of the Month Showcase & Voting Center
Chick is offline
Old 01-31-2013, 05:53 AM   #25
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
In the past, Ford has changed things due to customer complaints. For example, Ford used to put oil pressure gauges in lots of different vehicles. Customers complained that the oil pressure would drop at idle- especially in the summer with the AC on. Nobody sued back then, but there were plenty of complaints. Ford then put a resistor in the oil gauge circuit, and changed the sender to a switch- now oil pressure remained steady as a rock, until it would drop to nothing at 7 psi about 1 second before the engine locked up.
I hope Ford will get on the ball and fix this horrible issue for you. How can a 21st century digital man such as yourself survive without knowing the exact outside temperature? Maybe we'll get one of those famous Ford fixes. Instead of actual temperature- what if it simply said: Icy Cold, Cold, Sort of Cold, Warm, Hot, Sweaty Stinky Hot, Hot as Death? Then you'd know exactly what you were up against.
You might want to sue your weatherman too. I've noticed that they are off by as much as 5 degrees every day.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-31-2013, 04:55 PM   #26
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
FF Reputation: 15 a_2000_se Great Standing Member
........the sensor is mounted in the mirror......
Does the manual say anything about what the accuracy is?
I was curious where the sensor was mounted. If the inside of your car can climb to over 100 degrees F on a winter day in the sun, think what the temperature might do inside your mirror. Same with the source of your reference temps. And then with a moving car vs. stationary temp sources - it may take awhile for ambient air to permeate the mirror assembly.
If you are looking for a meaningful comparison - you'll need a stable and controlled environment and a calibrated reference source. Depending on accuracy, traceable to NIST. How well insulated is your garage?
Comparing it to anything else may be part of the problem - especially if the sun is involved and/or the temperature changes quickly over a short period of time.
How important it is to you and to what expense you want to go to to find the answer is up to you. .... Remove the mirror (keep it electrically connected) and put it in an "Ice Bath" (bag of water and lots of ice). See what it reads after soaking for say 30-60 minutes. You know ice is frozen at 32 degrees F. - That becomes 'one' point for your graph/experiment.
Do this when the ambient temp is above freezing so you don't end up with a "Popsicled Mirror" (the other point on your graph deals with another known scientific point - "boiling water", 212 degrees F. But I don't recommend this or absolute zero either).
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
40k+ miles, now jinxed?
a_2000_se is offline
Old 01-31-2013, 05:59 PM   #27
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
FF Reputation: 9 UnbridledCarnage Good Standing Member
are you factoring in wind chill?
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
Mod for General Chat, Ford General chat, FocusXtreme, KY,NC,SC sections
Originally Posted by matmatician View Post
Racecar > Comfortable female.
UnbridledCarnage is offline
Old 01-31-2013, 09:36 PM   #28
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Memberjetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Isn't there a warranty for a reason?.....
jetrinka is offline
Old 02-02-2013, 12:15 PM   #29
viney266
Moderator
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
FF Reputation: 112 viney266 Excellent Standing Memberviney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
As a 26 year mechanic ( on bikes ) ...They replace the part with new...inspect the connections. it still works the SAME...let me ask...in my position as a tech ( thats what hipsters like to call us mechanics)...what would you like me to do next???? seriously? tell me...I would love to know.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 02-06-2013, 06:32 PM   #30
kemoe
Fan#: 109270
What I Drive: 2012 Ford Focus
FF Reputation: 1 kemoe Good Standing Member
According to Ford, the temp sensor is OK at + or - 3 Degrees F. When checked inside the dealership it is + 2 over. Since it is within specs while sitting in the dealership, there isn't much else to do.
The strange part about this sensor is that it has wild swings of 2 to 8 degrees over. The longer the car has been on, the higher the variation.
The sensor is in the passenger side mirror. The variations are seen during the day or after sunset so the sun does not seem to have much of an impact on the inaccuracy.
Thanks for the reply.
kemoe is offline
