Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 01-29-2013, 11:31 AM   #1
Julian@TireRack.com
FF Affiliate
Fan#: 102247
What I Drive: N/A
FF Reputation: 1 Julian@TireRack.com Good Standing Member
BFGoodrich g-Force Rival launch at NOLA
Well we spent the better part of our trip to NOLA Motorsports Park actually getting behind the wheel of four different vehicles, in four different situations. Everything from an MX-5 on the skidpad to a Ford Mustang FR500S on a 2.7 mile road course was in our lineup for the day.
First, some details on the new tire itself.
• Razor-sharp reflexes - The Performance Racing Core™ (PRC) is used to provide a reinforced internal structure and reduce sidewall flex for instant steering response.
• Designed to stick - An asymmetrical tread pattern with a large, solid tread blocks on the outside shoulder optimizes cornering grip.
• Raise the limit - The extreme Tread Edge™ (ETE) design brings tread compound farther down the shoulder for increased grip in hard cornering and predictable feedback.
• Consistent grip lap after lap — Silica-infused competition compound is used to deliver better grip from start to finish.
It will first be available in 15 sizes all with a UTQG of 200 AA A.
205/50R15
225/45R15
225/50R16
215/45R17
225/45R17
245/40R17
255/40R17
245/40R18
275/35R18
295/35R18
315/30R18
335/30R18
265/35R20
285/35R20
315/35R20
Here's a rundown of what I felt.
The first thing we did was a skidpad in a Mazda MX-5 testing the difference between the BFG family of performance tires, the Comp-2, the Rival, and the R1-s.
There was a small hump right in the center of the skid pad so you got a feel for unsettling the car and how easy it would be to bring back in. What surprised me here was how well the Rival fits right in the middle of BFG's lineup or performance tires. Average numbers were just shy of 1.0g for the g-Force Sport COMP 2, 1.1g for the g-Force Rival, and nearly 1.2g for the g-Force R1-S. Not a bad first impression to make on a day full of driving.
Next we headed over to a small autocross course in the new Subaru Impreza STi.
We made two runs on the Rival, followed by two on the Toyo R1R, two on a Hankook RS3, then one final lap back on the Rival. The huge thing here was the difference in tread wear!
Not only did the Rival wear better, MUCH better, it handled the course better as well. The turn in response was very crisp and immediate. The transitions on the other 2 tires almost felt like you were waiting for the tires to catch up with your inputs. On the STi on this course the Rival was much more predictable, consistent, easier to push to the limit and again, wore much better then it's competitors.
After we finished lunch we headed to the road course and met up with the Mustang FR500S. We took the Rival out for two hot laps followed by two on the Falken RK615.
This is where the tread compound on the sidewall really fills you with confidence. While both tires did well with the steady state cornering, the Rival felt like it could always take more whereas the Falken was right at its limit. Now not knowing the track or the cars that well I know I wasn't even close to the limit, but even I could tell a big difference between the two. The big thing that was easy to notice was under braking, the RK615 felt less stable. You had to apply the brakes sooner into a turn otherwise it felt like the back end wanted to get a little loose.
Finally we went to a high speed autocross course to drive some E46 BMW M3's and compared the Rival to the Hankook RS3.
Again, the big thing you notice here is tread wear and quick response time of the Rival. It didn't feel like you had to "push" the Rival to get good times, and while we didn't take lap times, it sure felt like I was working much harder to get the most out of the RS3's then the new Rival.
Overall I felt more confidant and faster when driving the new BFGoodrich g-Force Rival. When you combine that with what seems like a longer tread life, this will be a great addition to the Extreme Performance Summer category. We will be running our own test here in last spring/early summer, so when I know more, I'll be sure to share it.
888-428-8355 ext. 4798
Julian@TireRack.com
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
Fan#: 1
Old 01-29-2013, 11:40 AM   #2
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
Price range?
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is online now
Old 01-29-2013, 12:07 PM   #3
Julian@TireRack.com
FF Affiliate
Fan#: 102247
What I Drive: N/A
Anywhere from $117 for 15" sizes to $173 for 17's. (and $372 for a 315/35R20, let me know if you can get that to fit)
What size were you looking at?
Julian@TireRack.com
Old 01-29-2013, 01:37 PM   #4
old1030
Fan#: 104714
What I Drive: '12 Silver Focus
FF Reputation: 3 old1030 Good Standing Member
Great review post. I saw on your site there is 3-rib and 4-rib tire, whats the handling difference between the two?
old1030 is offline
Old 01-29-2013, 01:57 PM   #5
05focusST91
Fan#: 83640
Probably 215/45r17
Old 01-29-2013, 03:57 PM   #6
Julian@TireRack.com
FF Affiliate
Fan#: 102247
What I Drive: N/A
Originally Posted by 05focusST91 View Post
Probably 215/45r17
These would be at $147/tire and we should get our first order in early spring, mid-April is when it's set to for now.
The 4 rib only comes in tires 265 and up so each size only has one choice.
Julian@TireRack.com
Old 01-29-2013, 07:10 PM   #7
05focusST91
Fan#: 83640
how do these compare to the conti extreme contact dw tires? (summer/rain rated)
Old 01-30-2013, 01:15 PM   #8
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
FF Reputation: 23 wrc_fan Great Standing Member
They don't, and if you're asking that question, these probably aren't the tires for you.
These are competition tires dressed up as a street tire. I've seen quotes saying that competitors may want to have back up tires if faced with large amounts of standing water on race day.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 01-30-2013, 03:56 PM   #9
Julian@TireRack.com
FF Affiliate
Fan#: 102247
What I Drive: N/A
I would tend to agree. The DW is a great wet traction summer only tire. The Rival is a tire meant for the track on dry days. Can it be driven every day? Sure, and we'll know more about it's wet traction when we do our full test late spring, but I wouldn't but it with the intention of thinking it will be a good rain/wet tire, that's not what it was built for.
Julian@TireRack.com
Old 01-30-2013, 04:25 PM   #10
05focusST91
Fan#: 83640
Ok thanks
