oil pressure gauge help?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-28-2013, 09:16 PM   #1
ner_das_uc_k
Fan#: 105037
What I Drive: 2001 red zx3
Points 286, Level 5
Points: 286, Level: 5 Points: 286, Level: 5 Points: 286, Level: 5
Level Up 72% Completed
FF Reputation: 1 ner_das_uc_k Good Standing Member
where can i conect an oil pressure gauge to my 2.0 zetec with out putting it in the hole for the oil pressure sending unit??
There's no replacement for displacement except a big turbo!!!
ner_das_uc_k is offline
Old 01-30-2013, 09:48 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,693, Level 62
Points: 8,693, Level: 62 Points: 8,693, Level: 62 Points: 8,693, Level: 62
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 55%
the most common place is under/next to the coil pack. their is a torque bit plug that I believe is the right thread pitch and type that is needed. This is also a port that is often used for oil feed lines for a turbo.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-30-2013, 10:09 PM   #3
ner_das_uc_k
Fan#: 105037
Points 286, Level 5
Okay thanks I ended up putting a T on the pressure sending unit
Old 02-05-2013, 01:29 AM   #4
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
That can work well too.
amc49 is offline
Old 02-05-2013, 06:53 AM   #5
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,236, Level 41
Points: 4,236, Level: 41 Points: 4,236, Level: 41 Points: 4,236, Level: 41
Level Up 44% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I remote mounted mine on the bulkhead and used SS braided line from the previously mentioned port.
After researching areas to mount, the weight of the sending unit could stress the T and break.
I now drive a Japanese Ford.
macdiesel is offline
Old 02-05-2013, 08:47 AM   #6
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Here is what I decided on:
I used a steel adapter fitting which, in hindsight, was a mistake. Aluminum head, aluminum fitting - why use a steel adapter and introduce problems with dissimilar metals? Just dumb on my behalf. So I rummaged through my fittings collection to find an aluminum one.
As you can see I had to grind a little off the top of the t-stat housing.
This is for a mechanical gauge which is what you want, IMO.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 02-05-2013, 09:05 AM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 55%
What right angle fitting did you use?
If you go with a mechanical gauge then you want to make sure you use an isolator between the oil feed line and the gauge. Many tracks / events prohibit mechanical gauges that are routed into the cabin that have any liquids.
Using some line to locate the sending unit is a good idea I think I will do that on my build.
Hatch Nation #42
Old 02-05-2013, 09:18 AM   #8
teamDFL
teamDFL's Avatar
Fan#: 92060
1/8" NPT to AN3. Most tracks only prohibit fuel being plumbed inside the car. I am running Kevlar lined brake hose. Good to 2000psi+ and 500+. If it fails while being used to feed an oil pressure gauge, I've got bigger problems than the gauge.
I don't trust electrical gauges. They are too slow to respond in my experience and since most of the affordable ones are 90 sweep, they don't give accurate information. A gauge that isn't timely or accurate qualifies as a fancy looking idiot light in my book.
teamDFL is offline
Old 02-05-2013, 09:33 AM   #9
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 55%
^^ usually its not the line, I thought it was the gauge that they are worried about. The gauge could fail and cause hot motor oil from spraying,leaking into the cabin.
I was looking at getting mechanical because they are cheaper and provide better accuracy and generally faster response. But was informed by some local people that the auto cross scene where I live don't allow for mechanical gauges with out the isolator / diaphragm. But the isolator drives up the cost and makes it the same price as a full sweep electric.
Hatch Nation #42
Old 02-05-2013, 09:44 AM   #10
teamDFL
teamDFL's Avatar
Fan#: 92060
If your autocross club runs via the SCCA rulebook, those people are wrong. The will not allow a mechanical fuel pressure gauge without an isolator but oil is fine. You can read the GCR and Solo rules online to confirm.
teamDFL is offline
